Question about Tomtom GO 910
Switching on I have just borrowed a tomtom, and I can't turn it on!!! help!!!
Hi, I have a 510 and am sure that this is the same problem I had. You need to reset the Tom Tom. You can do this by looking into the base of the unit where you would mount it for the window attachment and recharger. Just inside the edge to the left where it connects you will see a small black hole. You will need a paper clip or something like that and push it into the hole. You will feel a slight 'click' when you have got it right. This will reset the Tom Tom. This will not remove any settings/saved destinations you may have had. I have had to do this on a a few occasions and have had no problems with continued use. Hope you have success.
Posted on Jan 27, 2008
Custom Content Issues on Fiat TomTom Blue&Me 2
It can be done but its not easy.
1. Borrow a tomtom off a friend that has an older version that connects upto tomtom HOME and not My Drive connect.
2.Make a copy of the contents of that device onto the desktop of your pc. (*create a folder and call it tomtom)
3. Now on the copy, your done with the borrowed unit. Open the map folder and add the 'car' images you want into the 'brand' folder. If it doesnt exist create one in the map folder naming it 'brand'
4. Now copy everything onto a SD card
5. Go onto tomtom website and download 'tomtom content transfer assistant' and install
6. Connect your newer device to the pc and run the connect assistant.
7. Plug in the sd card when asked (connect old device)
It will then copy start up, shut down images, brand folder over to the new unit.
This should allow what ever you put in the brand folder to be displayed.
Jan 22, 2014 | Tomtom GPS
In-laws borrowed the gps it now does not work at all, they say nothing happened, but it will not even turn on. When I hold the on switch down it flickers like it is coming on, but nothing happens. Any...
TRY HOLDING DOWN THE POWER BUTTON FOR AT LEAST 15 SECONDS THEN RELEASE THE BUTTON THIS SHOULD FACTORY RESET YOUR TOMTOM XL... TOMTOM CHARGE £65 FOR THIS TRY ITS FREE
Aug 07, 2011 | Tomtom One XL GPS Receiver
Tom tom goes off when ignition is turned on.....could it be an earth problem in the car.it works fine when the ignition is off
When the ignition is off its likely its drawing power from the tomtom battery - with the ignition on it may be getting a small amount of voltage from the car cigarette lighter to make it run from there, but not enough to power it properly.
I'd suggest replacing/seeing if you can borrow one of the car charger leads to see if that makes any difference. If not it may be in an issue with your cigarette lighter output in the car which can be checked by your local autoshop.
Hope this helps.
Mar 16, 2011 | Tomtom TOM TOM ONE WE V3 GPS Receiver
My gps tom tom turns itself on waht could be
If you search for "TomTom turns itself on", you will find that there appears to be a problem which TomTom will not acknowledge. Mine always turns itself back on exactly (to the minute) one week after being switched off and runs the battery down. Tomtom have got me to reformat and had it back for repair but the problem remains
Oct 10, 2009 | Tomtom ONE GPS Receiver
When driving with my tomtom turns its self off
I had the same issue and it was a defective power cable. Try to borrow one and if that fixes it, bingo. If not, it is an internal issue and must be sent back for service.
Apr 23, 2009 | Tomtom ONE v3 Car GPS Receiver
Blinking white blank display after turning on
Try resetting your tomtom by inserting a paper clip through the reset hole found underneath. One quick press is all thats needed. Charge the tomtom first now and then switch on after its had a good charge.
If this doesnt work , please reply again and i'll try and help further.
Good luck
Nov 08, 2008 | Tomtom ONE GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Switch on problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 09, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom GO 910 Logo
32 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
