Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Locked door Hello, The hotpoint Aquarious washing machine wasn't working as it was saying that the door wasn't locked. Consequently I placed something inside the switch to press the sensor permanently down to ensure it appeared to be locked. It then worked fine and washed great but the door will not open. How do I get in and if/when i do, I'll be back to square one again. Thanks Paul pmuz42@hotmail.com
    Scholar:
  • 90 Answers
Probably the latch is wedged with the item you jammed in it..
While trying to pull the door open you might try using the palm of the other hand to hit the area next to the latch. When and if you get back in and hopefully without breaking something, take the switch out and bend the metal lever on it so it sets higher and thus allowing the door to make better/earlier contact. It might be possible to get at the latch from underneath if you lay the unit on its back????Not sure, but worth a try. Let me know if you need more help.
Posted on Feb 10, 2008
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
No power to hotpoint aquarious 1000 after changing door hinge
First check the wall outlet has the correct voltage supply, if it is having the proper voltage.
It sounds like when you changed the door hinge on the door lock system is getting failed, and it damages the timer. Since the timer is damaged there is no power available to the washer.
Other possibilities are the failure is either the control board, power cord or a loose or bad connection between the power cord and the control board.
However, you need technician's help to diagnosis the problem related to controlling board.
Hope this helps.
Shane
Feb 12, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Jun 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
Jan 29, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
