Question about Sony DVP-NS71HP DVD Player
Sony DVP NS71 Component Video split frame
I had a Sony DVP-NS71HP that developed a problem. Using the component video output, it worked fine for a while, then started having a problem. The display shown on the TV ends up with the scene split in half vertically, there is a line going up and down in the middle of the screen and then part of the scene on each side. I returned the player for another one. Worked fine for a while, now it has the same problem. Any ideas?
  • cjgauss Oct 31, 2008
    I have the same problem. It's probably because I'm trying to use the same DVD player that I had used on a 16:9 widescreen TV on a standard 4:3 TV now.
    I tried messing around with the settings to get it to work, but it still does it.
    But I think the only solution is to use a standard yellow RCA video cable at this point, instead of component output.
    My DVD player is a Sony as well, DVP-NS700P, or something similar to that.
    Problem Solver:
  • 5 Answers
You've inadvertently turned on the progressive scan. Look up in the manual, or ask customer service online, how to turn off progressive scan.
Posted on May 19, 2010
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
Can a Sony DVP-NS710H work with a non-HDTV? I have an older TV model (2001) and need a new DVD player. I am looking at this Sony model and would like to purchase.
yes, you must have at your tv one of this plugs: Connector Type Sony DVP-NS710H 1 x Composite video output ( RCA phono ) - Rear , 1 x HDMI output ( 19 pin HDMI Type A ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x Audio line-out ( RCA phono x 2 ) - Rear , 1 x Digital audio output (coaxial) ( RCA phono ) - Rear on your tv the connector is input.
Feb 14, 2010 | Televison & Video
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Hi, I have connected component leads from my dvd
Enable the component output on the DVD player menu. Sometimes the component output is shared between RGB/S-Video/Component, make sure you select Y/Pb/Pr on the player's menu.
Nov 04, 2009 | Sony DVP-NS51P DVD Player
I just purchased a Sherwood RD 6513 reciever, I'm trying to connect a hd cable box (motorola dch 3200), dvd player (sony dvp ns710h) and a rca hd tv (l32hd41). I connected hdmi cords from both components...
Hi! I will be more than glad to assist you. I f you are going to hook up your cable box - motorola to the sherwood receiver, connect an hdmi cable to the back of the motorola cable box, there is only 1 hdmi output there, then connect the other end to the sherwood receiver on the hdmi input, then connect another hdmi cable to the hdmi output and the other end goes to your rca hd tv.
for the sony dvp, you have only one hdmi out, connect an hdmi cable to the back of the sony dvp if u have another spare. connect it to the hdmi input of the sherwood receiver. there is only 1 hdmi output at the sherwood, so u need to use a component cable to be connected at the back of the sherwood receiver component output then the other end goes to the component input of the hd tv.
if you dont have anymore hdmi cable to hook up your sony dvp, u can use component cable, the connection will goes like this, connect a component cable on the output of the sony dvp and the other end goes to the sherwood component input then connect another component cable to the component output of the sherwood and the other end goes to the rca hd tv on the component input.
I hope this will solve your concern, if you have any question, u can get in touch..
Aug 21, 2009 | Televison & Video
Dvd in black and white should be color
Your probably had connected with a component video without changing the video setting!If you video setting is under composite/S-Video output but you end up connect the video source with component video cable,you need to go to the setup to change it.
It could be the other way around too!
solutiondoct
Nov 01, 2008 | Sony DVP-NS315 DVD Player
Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
Dec 31, 2007 | Denon AVR588 Receiver
Sony DVP-NS315 cant play only Video Disc
If you are using just a "yellow" ended cable for the video, maybe your custom settings are set to use "component"? I have been using this same dvd player for a while with the component video out and it works fine. I hope this helps.
Sep 30, 2007 | Sony DVP-NS315 DVD Player
Sony DVP-NS71HP DVD Player Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
