Question about Hitachi 43UWX10B 43" Rear Projection Television
Blue doesn't seem to line up
When we first turn the tv on the picture is perfect, and then about 1 min later we get a yellow line on top. seems like the blue light goes out of allignment. tried the majic button several times, even after 20 min.a couple of times now the tv has been working great and then the color goes again. tried to allign the blue light manualy, no luck. Any ideas?
  • tazmax Jan 29, 2008
    by tazzmax its been a few days and now the yellow comes right away and the volume is off and on. HELP!!!
  • 1,694 Answers
Blue convergence IC is bad....change both,,,original number
Stk392-110 replace with upgrade Stk394-160E Hitachi part
# CZ 01341 ....also check B+ feed resistors for over-heating
Posted on Feb 04, 2008
Mitsubishi WS-5541 light blue glow
I know these sets pretty well--worked on a lot of them when new and later--one of two possible ideas=
1. Either a odd convergence problem==confirmed or denied by going into the convergence menu (in customer menu) and selecting advanced which will bring up a grid of lines--if see the same issue (I will attach a photo of a Mitsubishi with this problem) it can be fixed.
2. Some sort of issue with the circuit board on the end of the Blue tube(you are missing blue=black) but usually in this set if that happens it is uniform and on both sides of the screen, not the top.
Let me know what you find.
I doubt it is convergence, but does not hurt to look--if the missing area was perfectly rectangular I would suspect up/down centering adjustment.
There is one other possible thing to try--we will leave it for last--set has 3 hidden menus and one is OPTION menu which allows a hard reset of entire set--sets everything back to factory except convergence adjustments which are stored in another area.
Apr 06, 2012 | Mitsubishi WS-55411 55" Rear Projection...
I purchased a 32" Dynex
You only need to plug in the Red/White/Yellow plugs. Make sure you plug them into the correct colors on the TV. Most HDTVs have Red/Green/Blue ports. DO NOT use these ones, they are for receiving HD video signals. A lot of HDTVs also have the Red/White/Yellow plugs on the side of the TV (often labeled "Game", maybe something like "Video 3")
The Red/White/Yellow cables are known as RCA cables or Composite cables so look for any ports with those labels as well.
May 09, 2011 | Nintendo Super NES Console
TV wont stay on.
Similar problem with my Sony. unplug for 36 hours and try again
Aug 13, 2009 | Samsung HL-R6767W Replacement Lamp
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
No Blue
The bulls eye is what us TV repair guys call it. It is a perfect description. The tube is good. The automatic degausing circuit is not working because the black square thermistor D805 needs resoldering on the bottom of the board. You will find that a magnet will affect it, and a degaussing coil will make it look perfect for 1 week. Soldering the thermistor is a permanent solution.
Mar 24, 2008 | Panasonic CT-27G21 27" TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Hitachi 53SBX10B
It sounds like the lamp is failing.
Jan 06, 2018 | Televison & Video
Hitachi 43UWX10B 43" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
