Question about KWorld PCI TV/FM Tuner, DVD Maker Card, Model "Xpert TV - PVR 883(VS-LTV883RF)" - Power Producer 2 R... (XTVSLTV883RF)
Power producer trying to open backed up video files from my hard drive video recorder.Want to edit files and produce a dvd.The program states it Failed to open video files?
0 characters
1 Points
Card crashes my pc to blue screen when i hit record. everything works but this function and its what i bought it for. to record video from vhs to computer. please help
Try placing it in a different PCI slot. The IRQ may already be assigned to handle too many for this card. Also state the blue screen code if you can, the make and model of computer motherboard would be helpful as well. In your Bios see if your shadowing is enabled if so try disableing shadowing.
Jun 01, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Hi im a doctor doing cardiac ultrasound and we need to record the videos to highest quality. Our ultrasound machine has an S video output - how can we record at 1080 or higher resolution - what hardware do...
There are a whole load of Video latch on devices for a PC, which, in my view are fairly useless.
I'd go down the route of buying a DVD recorder with a hard drive. You'll need one with an S-Video input. And many now step this up to certainly 720P for a high def, output (HDMI) Newer ones will probably step up to 1080p.
The flexibility of a DVD recorder with a HDD will allow you to record as many takes as you want, edit and title them, also write to DVD if desired.
I'd go for the machine with the largest possible hard drive I could afford, these high def data files are usually pretty huge. Especially when uncompressed.
Worth checking for one that also has a USB port for quick file transfers.
Finally, if funds are available, then a Blue Ray recorder with a Hard Drive. Again make sure you have a S-Video input, USB port and the output ports you need. Blue ray will by definition mean you're using high def. quality video.
Oh ......... check that the box that you do buy also has a suitable connection for the monitor you're using.
Here's a url for the wikipedia website on the subject:-
Towards the bottom, there are links to Extra High def 1440p and Ultra high def 4320p
I would imagine we're stepping into the realms of financial fantasy with this stuff, but its worth a read.
May 31, 2011 | Leadtek WinFast PVR2000 Video Capture
When I capture video from vhs, the result is a lot worse in quality than the original tape. I have tried capturing avi and mpeg, it makes no difference. fixed bitrate at 8000, no difference. Highest...
If you have the option, try capturing your video as MJPEG or DV format without compression, also the resolution must be 720x480 pixels (for NTSC) or 720x576 pixels (for PAL).
It will create a huge file !!! After this I recommend a dvd conversion with deinterlacing for better picture quality.
Hope this helps!
Oct 07, 2010 | DekCell EasyCap USB 20 Video Capture...
What is a USB tv box and what does it do?
This is Teac's description of what this unit can do.
TEAC's TV Tuner enables video and regular Television viewing on a notebook or desktop PC. Simply, turn your notebook PC into a portable TV! TEAC's USB TV Tuner is the smallest video capture USB2 device available today. The tuner allows you to watch, capture, and record your favorite TV/CATV, VCR, DVD or Video Camcorder on your PC, then burn them to VCD, SVCD or DVD disc with your CD or DVD Burner. Simply connect your analog cable or antenna to TEAC's TV Tuner, grab the remote and you are all set! The Tuner can be used to record video files or TV programs in DVD quality. With the bundled MPEG-1/MPEG-2 Encode software, recording a favorite video or TV program can be easily done. MPEG editor can be used to edit video files, which can then be burned into VCD, SVCD, DVD by using CD/DVD Maker software. The Tuner can support multiple video inputs, including S-Video, Composite Video, Coaxial/Antenna TV connector. It is a DVD quality TV/Video recorder.
Dec 08, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Crackly sound when recording vhs tape to disc
try new cables going from the vcr to the video capture (yellow red white)
Dec 01, 2009 | Pinnacle Dazzle DVC-100 DVD Recorder
Premier composite video caputer
To my knowledge, if the video feed isn't from a firewire source, or a file on a disk drive then Premiere will not recognize it. you would have to make sure the video isn't copyright protected, then have a program rip the files to your hard drive. DVD's usually store media in the .vob file format. Premiere, for legal reasons, doesn't access this type of file. you'd need some type of dvd backup software. there are many out there, some are even free.
Nov 26, 2008 | HP TV Accessories
I have Pinnacle Studio 10.8 with Dazzle transfering video from either Camara or Video Recorder. Camara transfer is OK. When video from the recorder is tranfered,on playing back the audio is fine but the...
Make sure that all memory resident software is turned off on your comptuer including any anti virus software.
If you have a secondary hard drive on your computer use that instead of the C drive.
Defrag your hard drive. This way you video will be save as a continous file on your hard drive rather than having it being saved into little pieces.
Make sure that the Dazzle drivers are updated as well.
The important thing is to shut down all memory resident programs and defrag your hard drive.
Jul 02, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Studio 9
Make sure that all background programs are not running on your computer. This includes, IMs, Anti virus, email programs. Defrag your hard as well. Your captured material may not be on contiuous file on the hard drive but fragmented into pieces.
What type of processor do you have in your computer and how much memory does it have?
Make sure that you run the PCI performance wizzard as wall as all calibration programs within Studio 9. Make sure that your DVD has recording enabled. This can be done by pressing my computer, pressing the right mouse button on the drive, select properties, select the recording tab, check enable CD recording on this drive. You may have to adjust the recording speed as well if the DVD player has trouble reading it.
Jun 09, 2008 | Pinnacle Systems Studio AV/DV Version 9...
SAA7130 TV Tuner...
DOuble click your speaker icon near the clock. click file then advanced, in the advanced menu select teh RECORDING radio box and click OK to return to your volume adjustments.
toggle the check boxes under each input and make sure they are turned up while you are trying to watch tv. when  you find the one that has the sound from your tuner go back to the advanced menu and make sure that input is checked under playback.
May 02, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
No sound from video captured through the handycam
use a cable to connect the line out of the card to the line in in your sound card. make sure line in is selected as the recording source.
Jan 06, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
TV Accessories Logo
42 people viewed this question
Top KWorld TV Accessories Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you a KWorld TV Accessory Expert? Answer questions, earn points and help others
