Question about HP Compaq Presario V2000 Notebook
Not getting on
If we turn on the laptop it starts and runs a little bit and gets off even the display wont come, but sometimes it comes . the fan rotates for sometimes and gets off
    Novelist:
  • 123 Answers
 Ensure that all cables are correctly connected and pushed in firmly. On some systems the mouse and keyboard connectors are very similar and next to each other. Ensure that the mouse cable is plugged into the mouse socket and the keyboard cable into the keyboard socket
Check that system unit are plugged in. Check the power socket by plugging in a lamp and ensuring it works
Check that there is power to the system unit. If you are unsure or do not know how to check this, either change the fuse or borrow a suitable lead from a colleague
Switch the PC on, watch to see if the keyboard lights flash and the fan is blowing air out of the back. The hard disk light should also flash on and off during the start up process.
If the system beeps several times when powered on carefully count the number of beeps - some systems use this to indicate the sort of error that has occurred, but remember that some computers produce one or two beeps as part of the start up process.
I you hear an unending series of long beeps, which usually means your mobo is not seeing the memory sticks properly. A short series of one long and three short beeps usually indicates a problem w/ the graphics card. Taking mem sticks and/or gfx card off and resetting them, with some contact cleaning if needed, generally solves the problem, provided, of course, none of these parts are damaged.
Don't forget to unplug the power cord before removing/inserting the memory and video card, otherwise you might end up killing them.
                                        or
Try this :
This is a very delicate problem because it offers many posibilities.
1. Usualy this happens when windows xp becomes corrupted and it will keep on rebooting itself and on rare ocasions it will boot but then crash for good.
Solution: This requiers a simple clean install of windows, after which everything will work normally.
Note: before trying the other steps we recommend to start with this one because is the most often of them all.
2. Problems with your memory cards. One or more memory cards could fail and your system will become unstable until those modules are replaced.
Solution: replace your memory module(s) with 1 from another computer which you know it works(from a friend,a neighbor)
3. Problems with your videocard which may have a failed circuit, thus resulting in a system instability.
Solution: replace your videocard with one from a friend just to see if it works with it.
4. In this category you will find the other posibilities that are very hard to detect and requier a PC expert to locate and repair them.
Here are: failed circuits, failed hard disks, failed motherboards, failed cpu's etc.
Solution: in this case we recommend you to go to a Pc service because trying to repair it yourself could hurt you or damage the computer.
Posted on Jan 27, 2008
    Novelist:
  • 113 Answers
It is likely that the ball bearings in the fan have started to go, and it is no longer properly cooling the system. In most cases it is necessary to replace the fan or entire HSF unit - which can be quite expensive.
I have been able to keep such a laptop alive for a while by using a laptop stand that has fans built into it, which usually provide enough cooling by pulling hot air away from the system.
Lawn Boy Gold Series self propelled 5.0I want to know what keeps spelling out the spark plug I run it for a little bit and then turn off and come back a couple hours later and it wont start spark plug is...
"I run it for a little bit and then turn off and come back a couple hours later and it wont start spark plug is wet"
From this little bit of info it sounds like the carburetor float needle seat is leaking and is filling the cylinder with fuel. A good cleaning and rebuild of the carburetor will probably resolve the problem and is where I would start if it was in my shop.
Without the actual model number I wasn't able to get any further info,
Nov 05, 2014 | Garden
My toshiba satellite c655d-s5080 wont come on even though the power light comes on and the fan comes on after a while
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 11, 2012 | Toshiba Satellite C655D-S5080 Laptop
My Lenovo G560 laptop gets switched off again and again while working.
this might sound a bit silly but if the fan is not running to keep it cool it will keep shutting down.try and blow away any dirt or dust that might be stopping the fan from running.
Aug 20, 2017 | Lenovo Computers & Internet
First ~ my screen went black and now it will not even power up. The power button comes on and goes right back off.
These little netbooks do have a tendency to overheat, so the problem could be that it's getting way to hot to even turn on for a little bit.
Have a computer technician do whats called a repaste, which is basically taking the netbook apart, and putting heat tranfer thermal compound on the processor. Also, have them check the fan, as a malfunctioning fan can cause the system to turn right off after a startup.
Hope this was helpful.
Apr 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
HP Pavilion DV2799ee - Display Problem
You actual Video card has gone faulty, probably from Overheating, either that or the "Coin" is twisting the board and it isn't making contact with the socket or such.. Generally by the time you see "Artifacts" the card has already been damaged, however slight.
Mar 09, 2010 | Computers & Internet
I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Feb 19, 2010 | Acer Aspire 4520-5582 Notebook
Sony vgn-s460: screen blinks, fan runs very loud
Possible clock timing of CPU is wrong. Is it two fan on this laptop? Maybe one is not functioning. Plus check your power supply if gives correct power!.. If none of this , it comes to the MB and possible a CAPS making problem. Need expert.
JMC
Aug 06, 2009 | Sony VAIO VGN-S460 Notebook
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Acer aspire 5100 wont start up
i think the computer gone to power save or hibernation mode. get the battery off from laptop then put it back, turn the computer on. it works, if not consult some hardware technician i think it is not a major problem it can be fixed easily. if warrenty is valid, avail it...
Oct 20, 2008 | Acer Aspire 5100-5033 Notebook
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
HP Compaq Presario V2000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
