Question about Nike Triax CV10 Wrist Watch
Nike Triax Backlight
The light stays on all the time. It is killing my battery within hours. Please help
  • 2 more comments
  • barts22 Jan 27, 2008
    Thanks for the advice, however it does not seem to be working still. The light is still on.
  • Anonymous Feb 05, 2008
    I'm having the same problem on a Triax 250
  • dlphinsfan Mar 21, 2008
    I am also having the same problem with a 250. I have replaced the battery and tried the AC trick several times with no luck.
  • Anonymous Jun 09, 2008
    My watch has the same exact problem. I tried the reset with all 4 buttons prior to reading this and that did not work either. I have also replaced the battery to no avail.
    Problem Solver:
  • 14 Answers
Usually after changing the battery you need to "ac" it, which means to restart the ic, or else the light will keep on. please check there is a area on the pc board says "AC". all you need to do is use a metal pin to contact it. if it dosn't work then try press all push buttom at same time, it has the same function as press "AC"
Posted on Jan 27, 2008
Nike triax
Tissot 1853 I don't know how to reset the time after I changed battery.Pleas held me
Oct 05, 2013 | Watches
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
I have a Triax Speed 50 Nike watch and the local jewelry store would not change the battery because the possibilty of damaging the wrist band that needs to be removed. Any instructions on how I can change...
You can't change it yourself without doing damage. You will need to send into Nike or more accurately an authorized nike watch repair center that is close to you hopefully.
Nike customer service or a google search for authorized nike watch repair in XXX-city will get one close to you.
Dec 27, 2010 | Nike Timing Triax V10 Watch
The start and stop buttons are stuck. so I can't even change the time or use the timer and any other funcion! They stayed down and I am not able to take off.Nike Triax mia
Did you just have the battery changed? Sometimes once a watch is open and things are moved around, the connection wires that are pushed by the buttons will need to be adjusted.I would take to a watchmaker/jeweler to have looked at.
Aug 18, 2010 | Nike Black Triax Mia Watch WR0104 001
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Mar 31, 2010 | Nike Triax CV10 Wrist Watch
Turn off hourly beep on nike triax fury
Press the Start/Lap button in Time mode to turn on/off. This also turns on/off the beeping sound when switching between the different modes.
Jul 07, 2009 | Nike Triax Swift Digital LX - Blk/Blk...
How do i change the time on this watch?
Try to find it here:
Rate, please.
Mar 29, 2009 | Nike Midsize Triax 50 Regular Watch #R0082...
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
Jan 27, 2008 | Nike Triax CV10 Wrist Watch
Nike Triax CV10 Wrist Watch Logo
174 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Nike Watch Expert? Answer questions, earn points and help others
