Question about Onkyo HT-SR800 System
Receiver display has disappeared but unit still works
How do I get the receiver display to come back. All of the components are working but I cannot get the display to show.
  • RouteB Apr 16, 2008
    Same problem different receiver (TX-SR805) - It's not the dimmer, Is there another solution?
  • RouteB May 11, 2010
    Same problem different receiver (TX-SR805) - Its not the dimmer, Is there another solution?
    Problem Solver:
  • 18 Answers
If you are talking about the vacuum display on the front of the receiver, it could be either blown and need replacement or simply dimmed. There is a dimmer button on the front of the unit that should allow you to select between three different brightness settings.
Posted on Jan 28, 2008
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Have DPD 503PU Pioneer Plasma Display TV. There is no place to place cable cord and there are two cords missing, one gray and one white. Can you tell me what these cords plug into and where to get o
This may be the PDP 503PU. There are supposed to be two parts to the unit; you appear to have the Display but not the media receiver and the standard accessories for the receiver.
The media receiver has the inputs for coaxial cable and component video. The gray and white cables are the system cables which feed the signal from the receiver to the display. Most of the on-line sources that I deal with do not have the system cables in stock.
The manual for the unit is available from Pioneer: .
This unit should go to an E-waste recycling agency, IMO. Without the receiver and the system cables, it's useless. I wish that I had better news for you.
Dec 31, 2011 | Pioneer Televison & Video
Kenwwod VR-615 - display disappears
Its becuase it is dirty inside, Unplug it. Take the case off of it. Get sum compressed air from a computer store or Walmart. Like 10 dollars. And just blow the whole thing out with that canned air. do it ever 3 months.. It should fix the problem for life!(:
Jan 30, 2010 | Kenwood VR615 Receiver
No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
Feb 14, 2009 | Yamaha RX-V661 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
I have a CDX-M8815X unit only works with remote commander
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from or
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
Nov 30, 2008 | Sony CDX-M8815X CD/Receiver/MP3 System
STR-DE597 Display is not visible
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Aug 04, 2007 | Sony STR-DE597 Receiver
Onkyo HT-SR800 System Logo
301 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
