Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Volume and menu does not display
I am having a strange problem with my TV. When I turn the volume up or down, the display that shows the volume increasing or decreasing does not display. The volume is increasing and decreasing, the display is just not showing. Also, when I choose Menu the menu screen does not show up either. Finally, when I choose Input, my input screen does not show up even though the input is changing when I hit the button.
  • 3 more comments
  • Anonymous Jan 04, 2009
    I have the same problem. Neither the input menu or volume panel show up. Instead I have thin lines where those should be. Can anyone help?
  • Anonymous Mar 22, 2009
    Same problem, also a blue horizontal line at the top of the screen. Unplugged the tv for 5-10 seconds and it's fixed, thanks for the help.
  • fishmaster3 Apr 10, 2009
    none of my menu appears on the screen, volume, channel, input ect.
  • Anonymous Apr 21, 2009
    LG not displaying any menu
  • Anonymous Mar 19, 2014
    tv comes on -have picture but can not get sound-sound bar does show up and shows that you are trying to increase volume but no sound what so ever
I had this problem on my Aquos (LC-46D62U). It was NOT a hardware problem. I recommend turning off the television. Next unplug the television for 5 to 10 seconds. This resets something for the television. Plug it back in and turn on the television. You should now be able to get your volume and other on-screen displays.
Posted on Feb 18, 2008
  • killerbee42 Mar 04, 2012
    Thanks worked perfect.
  • Bruce Whitehill
    Bruce Whitehill Jul 02, 2015
    Simple -- it worked!
  • 123 Answers
          The chip for the displaying function may be lost or some part connected to it must be damaged.Replace it.
   Your tv button is damaged ,replace it.
Posted on Jan 27, 2008
4 Suggested Answers
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
  • 85 Answers
SOURCE: no antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
Posted on Jul 27, 2009
  • 8457 Answers
SOURCE: Volume won't display and can't enter menu
U can unplug.replug about an hour later,it will reset it back to factory setting.Should work as before.
Posted on Mar 06, 2010
My tv hisses and gives off a strange smell
Some thing wrong with it. It might be either to its main power supply regulator circuit, or its horizontal output circuit. A through check up should be done. Contact any experienced service technician. Never switch it On, till the fault have been rectified.
Sep 26, 2012 | Televison & Video
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Cannot increase the volume on Coby TV
Your tv is on 100 but it sounds like its only on 50. There is a solution is go to the menu then go to sound and then turn balAnce all the way down
Jul 02, 2012 | Coby 40 TFTV4028 LCD TV
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
The ringer is tuened off on my GE cordless phone how do I tuen it back on?
  • Press the "Menu" button on the handset. This button is also the "Star" (*) button.
  • Press the right "Volume" button to browse through the menu. When the display shows "Setup HS," press the "Menu" button again.
  • Press the right "Volume" button until you see "Ring Volume." Press the "Menu" button to enter the ringer menu.
  • Press the left and righ "Volume" button to turn up or down the ringer volume. The default volume level is "L3." Press the "Menu" button to save your change.
  • Oct 17, 2010 | Uniden Cordless Phone
    Mar 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
    RCA TV picture bigger than screen
    if the tv width is ok try entering to service menu (do not use remote control) as follow:
    1) turn the set on.
    2) press the menu button and hold it down while pressing the power button.
    3) while holding down the menu button release the power button and press
    the volume + button.
    4) The screen will display a one line menu, on the left the parameter P00,
    and on the right the value of the parameter V00
    5) release buttons.
    6) using the volume + button change the right parameter until 76
    7) using the channel down button change the left parameter until 06 (vertical size)
    8) whith the volume + or volume - adjust the screen size.
    9) when your tv is OK back to parameter 00 using the channel up button.
    10) press menu button.
    and trouble solved.
    Mar 05, 2010 | RCA F32650 32" TV
    Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
    Hello Blindrid,
    What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
    Just to check that it has all work correctly. turn you volume upto a certain number for example 25
    Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
    Hope this Helps Please leave a thumbs up.
    Little Dish Fitter
    Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
    Message protected program by tv-pg
    Go into Menu /V Chip arrow key up to tv rating should show all locked volume down or visversa should should view all Note may have to volume up to get to options from menu depending on how old the tv is.
    Apr 04, 2007 | Emerson EWV403 VHS VCR
    No Volume Unless
    you might want to take it in to a repair station. The buttons on the front might need replacing.
    Jan 25, 2007 | RCA F36668 36" TV
    Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
    684 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
