Question about RCA F36650 36" TV
Can not get the sound to come threw the audio out in back of tv
I need to know if there is a specil wire i need to get or can any audio wire work . i went threw the menui and in the audio part it is saying the out specker are on . i don't have the manuel .
  • 58ekim Feb 01, 2008
    i know all about the internal and external speaker . the problem is i can't get the audio out in the back of the tv to put out sound with the speaker in the tv at the same time . it will do one or the other not both at the same time . i can't hook up my suround sound system and have to sound coming out of the tv at the same time . i have to switch it in the audio menu in the tv every time i want the suround sound to work .
  • El_Gangster1 Dec 22, 2008
    I hooked up the HDMI to my TV and my Home Theater , But now i want to know how i get my HOME THEATER to work , Such as play my Ps3. Do i need another Cable/Cord? Or its my TV thats not compatible with the HOME THEATER? My TV is HD!
  • RCA Master
  • 5,138 Answers
You have internal speakers/external make sure you switch on internal ,not external this is for hooking up other speakers on outside of set.Turn on Internal speakers!
Posted on Jan 27, 2008
How do I change audio settings to come threw my Samsung home theater system
How have you connected the TV to the surround sound, what type of cable are you using?
Dec 10, 2014 | Samsung Televison & Video
Hi i have recently got a lg surround system without a manual, i think all the speakers are set up correctly as i have done a sound test on it and they all seem to make noise however i am having trouble...
You should have 2 RCA jacks on your TV and on the back of your receiver ... a white and a red. These are the left and right audio jacks. Generally, I hook up the audio out from the TV to the DVD player, then from there into the receiver ... this makes it easier to turn off the connection to your receiver if you want to use the TV speakers for news and whatever (by turning the DVD player off). Once the RCA cables are all hooked up, the information should have no problem transferring to your surround sound receiver. Now that the connections are all made, check the settings on your receiver. Make sure that you have the surround sound turned on, and that the receiver has all speakers selected (hunt through the menus and find the "dolby 5.1" or "THX" surround options and turn one on. This SHOULD resolve the problem.
If this did not repair your issue, make sure that all of your equipment that you are running through is all capable of surround sound (if you have a really cheap DVD player like me, it may not be able to handle surround sound). If your TV is surround capable (LCD, Projection, and Plasma TVs are usually all capable of this ... CRT tvs are not always capable) but your DVD player is not, hook your TV's audio RCA cables directly to your surround sound receiver and you should be set. If your TV and DVD player are not capable of Dolby or THX surround sound, then you will probably not be able to use that feature, so your satellite speakers might not work, but the main left and right should still work fine.
One other thing that I have had issues with in the past is the connections on the back of the receiver. If you are using speaker wire (a lot of newer systems have input jacks instead of wire because they are easier to deal with) then make sure you have stripped enough of the wire to make a good connection in the back of your receiver. If you have too little wire exposed, or if you have pushed the wires in too far, the insulator on the wire will block the connection. To be sure this is not the case, be sure that only the exposed part of the wire is sticking into the back of your receiver. Also, make sure that you are not trying to run too much wire between the receiver and the speakers -- if you have a 100ft wire between the system and the speakers, they might not be getting a strong enough signal to work -- you can buy a signal amplifier for your speaker wire, or you can use a shorter wire.
Most likely you have to find the settings in your menu and turn on the other speakers. If the sound test worked for all of the speakers, the connections are all good, and it is the system not telling the speakers to work.
May 26, 2011 | Nintendo Wii Console
Getting a new panasonic g20 plasma i want to make sure have right cabling inserted in the walls to ensure that plasma will play in surround sound through lifestyle 50
You COULD slave your Bose to the TV's version of audio via the TV's digital audio output but WHY? The best audio will always come directly from the source (cable/DVD/BD/game/etc) so run the highest quality audio directly into the Bose from them and the highest resolution video directly to the TV from them. Let the specilized electronics in each do what it does best without intervening connections and alteration.
Your various components will determine what the TV needs to support. If you're working with a professional installer he may have recommendations for the present and future cabling needs.
May 27, 2010 | Bose LifeStyle 50 System
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Problem hooking up my system to the T.V.
check the back of you tv and see if it has the audio out plugs. if it does the you plug the white and red audio cables into the audio (in) on the dvd player and the audio (out) on your tv. then press function on your dvd player until the light on a/v comes on.
Jan 04, 2008 | Durabrand STS92 System
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
RCA F36650 36" TV Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
