Question about Canon EOS-20D Digital Camera with 17-85mm Lens
Not being able to shoot
Some 2 weeks ago as I tried to shoot with my EOS-20D w/ Canon's EF-S 17-85mm lens, it didn't "wanted" to shoot. I imagined being a focusing issue, so I switched to Manual Focus, took a picture and then back to Auto Focus. It worked well. But now the same problem appeared, which means that although the camera can get the subject focused (and the focus light gets solid, not flashing), it simply doesn't shoot. I already tried switching lenses and the problem remains the same. Battery fully charged and firmware is the latest version (2.0.3). Any ideas of what can be done in order to get it working? I'd appreciate!!
  • benxt Jan 27, 2008
    thanks, but none of this is the case. don't have the battery grip, cf card is well fit... anyone else has some clue?
    I must mention that I also re-formatted the cf card from the camera. It didn't help either.
    Genius:
  • 1,067 Answers
Http://www.photo.net/equipment/digital/sensorcleaning/
read sum of these links
http://alalper.com/before_cleaning.jpg
http://alalper.com/after_cleaning.jpg
My change was that, I inverted the cammera so the dust fell out after blowing
Posted on Jan 27, 2008
  • 3 more comments
  • nick helpap
    nick helpap Jan 27, 2008
    also what kinda sd card do uuse ?
  • nick helpap
    The 20D camera as originally sold had occasional lock-up problems (became unresponseive to user input) often right after changes lenses and/or flash cards. Removing the battery and re-inserting it restored the camera. Canon's 20D firmware update 1.0.5 fixed the lens-communication and CF-card communication problems in most cases, though some people still report lockups. Firmware 1.1.0 added a fix for horizontal banding at high ISO settings when using the built-in flash. There is a link for firmware downloads below under "Canon Links".
    Note: if you are using the BG-E3 accessory battery grip with a heavy lens, the grip can pull away from the camera body enough to release the microswitch by the battery door that locks out CF memory access. This could cause any number of problems if it happens while writing to the CF card. This can be fixed by using a folded-over business card, adhesive velcro pad, or the like on the far edge of the grip, to the outside of the locator-pin near the attachment thumbscrew. In this way the grip is "pre-loaded" against the camera body when it is screwed on, and no reasonable amount of force will open the microswitch. The same thing can happen with the CF access door if it is pushed slightly open by your right hand palm (less than 1 mm does it). One solution here is to cover over the door with another surface. Black gaffer tape is one possible, if crude option.
    Holding the MENU button down for 8 seconds continuously will hard-reset the camera, restoring all factory default settings
  • nick helpap
    Canon Links
    Canon 20D page link to register your 20D, specs, and brochures
    Canon user manuals 20D user and software manuals online in PDF format
    Canon downloads download new firmware, drivers, software, SDK
    Canon 20D tech report Some details regarding the new design features found in the 20D.
    CMOS sensors a brief description of Canon's CMOS sensor technology
    Tech Report mostly for 1D-II, 1Ds-II cameras, but with useful general info and tips
  • nick helpap
    ill keep serching for sol
  • nick helpap
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
I just received the canon EF 100-400m lens for Christmas. I was using it on my canon EOS 20D and it just shut down. I thought I had a dead battery but even after charging the batery, I couldn't get my...
I've had this happen right in the middle of a shoot, what I found first was that I had pushed the lens release button and the lens moved ever so slightly but enough to mess up the connections and everything went dead. Another thing is not having the battery at a full charged but if it's not coming on at all I'd be checking the battery door make sure it's latched securely. Next make sure the Card is down and locked in the seat and the card door is closed and locked. Clean the contacts on the camera body and lens (this generally gives an error 99 though) with a red soft pencil eraser keep the lens as vertical as possible when lightly cleaning (polishing) the lens contacts. Keep the lens cavity pointing down as much as possible while cleaning (polishing) the body contacts another thing and my 20D is coming due for this as well is a back up battery this replacement is found on page 35 of your manual Oops not manual here is a diagram
Diagram
Here is where to look and what to do diagram
Diagram
This should put you back into the photography again Cheers Have fun with that great lens
Jan 17, 2011 | Canon EOS-20D Body only Digital Camera
My lens is locked and i cannot zoom
I had the same problem with the same lens. Over a few months it got lose, eventually getting so sloppy that it dropped if my 40D was held down. 10 days ago it jammed and the zoom was locked. I sent it to Canon and received it back in a week and it is now like new. Please don't try and fix it leave it to the experts at Canon. Not sure what the cost was as mine was still just under warranty
I think that this is a common problem with this lens and beleive that something in the lense works loose and eventually drops into the mechanism.
Jun 28, 2010 | Canon EF-S 17-85mm f/4-5.6 IS USM for EOS...
00 on the F info (aperture shows 00)
I'll assume the lens is an AF lens? Most of the new Canon bodies require AF contacts. If there isn't the right contacts, it won't work. There are suppose to be AF body mounts that will tell the body that there is an AF lens, then use the old lens in Auto mode.
If it's an AF lens, the internal electronics are toast. You could send it out, but they'll charge you a "look at" fee. That could run into many bucks. Give Canon a call.
Jul 26, 2009 | Canon EF-S 17-55 f/2.8 IS USM Lens
Hi all, I wonder if you can supply some advice regarding a Sigma17-35mm lens I purchased earlier in the year. Basically if I use the automatic or 'P' setting on my Canon EOS 30D camera the image is over...
Try your EOS in AV (aprature value) mode. You should be able to adjust your aperature value in 1/3 or 1/2 steps dependind how you have your Custom Functions set in your camera's menu. Possibly the lens you purchased is for an EOS 35mm. If you use a 35mm lens on your eos there are some calculations you must use. When using a 35mm lens on the EOS 20D, 30D, 40D and 50D bodies, you must first calculate your focal leingth by 1.6 times. With this, your exposure changes as well.
The only EOS Digital SLR bodies that use a 35mm x 24mm CMOS sensor are the 1D and 5D. My wife uses a Tamron 18-200mm f3.5-5.6 lens on her 20D and loves it.
If this makes no difference, you may have a defective lens.
Nov 29, 2008 | Sigma Cameras
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 20d error 99
does the camera work OK with other lens? If yes then Lens is the patient - only 4 moths old -send it back
Sep 12, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Canon EOS-20D Digital Camera with 17-85mm Lens Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
