Question about Radio Communications
1988 pace arrow electrical problem
I can put a hot battery in my rv, and it will usually crank. But, I have a small surface mounted compass on my dashboard, and when I turn on my ignition to crank, that compass goes crazy, spinning forward,backwards, all around, and want stop, and this compass has no electrical going to it, it's just sitting up there, and also, several of my gauges on my instrument read incorrectly. I'm looking for a starting point to try to troubleshoot this problem, and don't know where to start. I had the alternator tested, and it tested to be good. Please give me some help..........thanks RANDY MORGAN
The Alternator only comes into play AFTER the vehicle is running so I would bench test the starter for excessive starter draw. If the starter tests good I would change out the Solenoid. That may explain the guages reading incorrectly. As to the compass, possibly a shorted wire near there could cause it to spin. Try relocating it.
Posted on Feb 03, 2008
How to id 74 pace arrow motor
Look at the motor builder not at the RV section, Louis
Aug 24, 2016 | RVs
Fuel problems 1988 pace arrow
remove the tank unit and check it as their is a gauze filter on the bottom of the pick up and it could be dirty
Apr 05, 2015 | Cars & Trucks
Why wont the parking brake release on my 1988 pace arrow motorhome ford chassis ?
As a mechanic II would have a look at the manual before trying to move it.
Jul 10, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
Pace arrow fuel pump
On carb models it on the passenger side of engine in front of engine mount. Electric models suggest following fuel lines motor home companies put them where ever it will fit. GM puts them in the fuel tank.
Nov 01, 2013 | Vehicle Parts & Accessories
Detailed wiring diagram required for 1993 Pace Arrow RV.
I just recently purchased a 1993 Pace Arrow and I believe I may have all paperwork on the 454 engine but its a gas engine. Not sure if it helps but I also remember seeing a chevy chasis book in the package.
Nov 30, 2011 | Cars & Trucks
I bought a used 1984 pace arrow on a chevy chassic, while checking out the wiring I have found so many wires attached to the fuse box and other wires, I am trying to find a wiring diagram for both the...
you will have to contact pace arrow if still in business for the 120 volt wireing.they are all pretty much the same in similar years motor home so generic rv how to manuel would be ok.contact chevrolet for a cab and chassis manuel. as a side note, on the 120 volt system the black wire is not a ground.it is the hot wire.the white wire is nutral[ground] the 12 volt stuff is color coded like a 1984 chevy
Jun 07, 2010 | 1989 Cadillac Fleetwood
In a 1997 pace arrow,where do you turn on the hot water heater?
THERE USUALLY A PANEL OF SORTS SOMEWHERE AROUND THE GALLEY, ON THE WALL, STOVE HOOD, BEHIND THE CUPBOARD DOOR ABOVE THE ENTRY DOOR OR BESIDE IT.
Oct 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Radio Communications Logo
126 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
