Question about LG 42PX5D 42 in. Plasma HDTV
LG DLP Rear Projection RT44SZ21RB
Screen had a shadow top right corner,went down about six inches on the angle , after a few days about two thirds of the TV was the same {now thwe weird part} it seemed to sink to the left of the screen ,where it has stayed. remaining picture is a little dull
  • 2 more comments
  • jerry30 Jan 27, 2008
    Thanks Is it very dear to Fix? I'm In Australia
    No, I didnt have checked with she who must be obeyed ,
    gday, coldcut,have looked up parts list in LG for the model that I have there is no thing listed under sync circuit , is it under something else
  • awesomeauto Nov 24, 2008
    hi there
    i have a shadow down the rh side of the screen , about half inch wide,,left side perfect,,,any ideas on my RT44SZ21RB
    [email protected]
Had Same Problem with Mine turned Out to Be The Light Tunnel
Posted on May 28, 2009
    Genius:
  • 1,554 Answers
Classic symptom of a failing sync circuit.
do not run it as it will likely smoke soon.
Call Repair tech now.
Posted on Jan 27, 2008
  • Karl Whisenand
    Karl Whisenand Jan 27, 2008
    As this is a newer unit only a person with experience on this model can likely fix it.
    It is just some of the components heating up or drying out.
    but folks only replace module now days.
    It won't be cheap, but you got the extended 5 year warranty right.
6ya staff
SOURCE:
The top 10 inches of my screen is breaking into separate bands of grn/mag/yellow that continue across the tv till half way and then it skews to the top right corner. It started doing this about 2 weeks...
Ur convergence is dead.U Know how to solders?Must replaced the 2 Convergence ICS and all it resistors.Tries Tv Repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 53UDX10B 53" Rear Projection...
LG 52in rear projection HD TV
it will be the polarized filters in the optical engine which you cant get anymore you will have to get a new optical engine fitted, take it down to ure local service agent for a quote
Jan 20, 2009 | LG RU-52SZ51D 52" Rear Projection...
LG DLP Projection TV Green/Brouwn vertical Bar
Hi there.
The excessive heat from your lamp has burned one or 2 polarizing lenses.
To replace this you have to pull the optic engine out of the unit and dismantle it.
You will see 3 square lenses in there, remove one by one until you find the burned one.
Then go to ebay and type in hoya polarizing lense.
Buy the 72mm one and cut it to size.
hope this helps.
Sep 30, 2008 | LG RU-52SZ51D 52" Rear Projection...
Shadow down left hand side of screen
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Jul 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Lg 44inch dlp
This could be a problem with the light funnel or alignment of the light engine.
I woud contact a service center for a quote.
Nov 19, 2007 | LG RU-44SZ51D 44" Rear Projection...
Rear projection lg lcd 44 inch
Sep 29, 2007 | LG RU-44SZ51D 44" Rear Projection...
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
Zenith E44W46LCD
This is likely a bad light engine, or so I'm told by the LG electronics. The cost of the part can be as much as you paid for the set itself. Call customer service and let them know of your problem and then ask to escalate the issue. LG electronics, although not admitting fault, tried to find a service rep but eventually bought back my set at a pro-rated amount. Overall, I was very satisfied with their support. Best advice I can give you is to not buy a rear projection set again, LCD or DLP. Lamps are expensive and design is unreliable. LCD flat screen is your best option, in my opinion.
Aug 29, 2007 | Zenith E44W46LCD 44" Rear Projection...
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
LG 42PX5D 42 in. Plasma HDTV Logo
436 people viewed this question
Ekse
RONALD CARTER JR
