No sound in Toshiba equium A100-338
Everything was fine until my daugther connect a projector to the external VGA port, then we lost the sound .
  • Ami Plaes Jan 27, 2008
    Dear melvanz
    I have done all the steps you have mentioned . The system detected the audio device without any error and the I installed the suitable driver from Toshiba and the volume is not muted,I verified all the devives in the device manager and I didnot find any conflict all the parts works fine. I also formatted the harddrive and used the recovery DVD to reinstall the operating system without but still have the same problem .
    thank you.
  • Ami Plaes Jan 28, 2008
    Dear melnavz
    I talked today with toshiba support and explained the problem, I send the pc to be repaired in toshiba repair center.
    Thank you
    Have a nice day!
    Genius:
  • 1,226 Answers
Verify if the system detected the auidio device:
go to control panel and then system, hardware tab, then device manager
if no errors on the sounds and video controller mean that device is installed; if has error then reinstall the driver of your device.
if no error on the device
verify the taskbar if find the volume maybe its muted. and the the connection of the speaker.
may this help. thank you.
please leave comment before you rate.
Posted on Jan 27, 2008
  • Emelio Navaja
    Emelio Navaja Jan 28, 2008
    Dear amipales :
    I can't see any errors in system, however you can test your sound port by connecting any external speaker, If you already used external speaker, then in can guess that the wire connecting to the port maybe lessen or something materials connecting to the speaker. you can try fixing that by your own, however if afraid to open the system i'd rather suggest that repairman is very suitable in that case.
    wish you good and have a nice day!
Toshiba satellite C855D-S5105 HDMI
For the Toshiba Satellite C855D-S5105, HDMI is an option.
If present, believe it to be on the Left side, same as the VGA port.
[General example of VGA connector (Port), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Note* Color is not always Blue. Scroll down a little for VGA Cable example ]
User Manual states plug external monitor device into laptop, then turn external monitor device on.
External monitor device should automatically be seen by laptop.
If not press, and hold down on the Fn key, and at the same time, tap on the F4 key until the display option you want is shown. Then press the Enter key.
Touchscreen?
That requires a knowledge of Windows 8, which I do not have a full understanding of yet. The User Interface of Windows 8.
It isn't stated by Toshiba, (At least that I could find), as to if the HDMI port; is just that. An HDMI port, or a Mini-Port HDMI port,
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
There are HDMI adapters, and HDMI cables; that adapt from regular HDMI to Mini-Port HDMI.
There are adapters that connect to a VGA port, and convert to an HDMI port.
Not the answers you are seeking? Please reply in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 12, 2013 | Toshiba Computers & Internet
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 12, 2013 | Samsung Q32032P PC Notebook
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
How to connect the acer aspire one to an epson projector
The Aspire One has an external VGA port so you will use that and a VGA cable to connect to the projector. You may have to press the Display mode button (typically Fn+one of the function keys with the rectangle 'display' on it) to enable the external VGA port.
Mar 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Pd527 not displaying vga from vista run computer
Based on my own experimentation, I have found out that if I click on the “Connect Display” button from the Windows Mobility Centre, it will auto-detect whether a monitor or projector is connected via the external display port. If it does find a display, it presents you with a new screen with an option to “Duplicate my desktop".
Sep 28, 2008 | Acer Office Equipment & Supplies
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Computers & Internet Logo
1,079 people viewed this question
Alun Cox
David Payne
David Payne
