Question about Kenmore 64942 Electric Dryer
Where is the fuse?
Dyer is running but not drying-no heat. Wanted to check fuse but can not find it. Help please.
    Problem Solver:
  • 7 Answers
The fuse is located in the dryer fan/blower wheel cover and is a one time fuse, which means it is not resettable. I did a look up for the kenmore model # that you gave and I cannot find your model listed. If you go to parts.com and do a search for your dryer you will be able to see all the drawings on your dryer. You will be able to find the replacement part # and how to get to it. Test your fuse to check if it is open if it is, then replace the fuse. There is also a temperature sensor on the back wall of the dyer drum (it is a small metal circle close to the exhaust outlet). Sometimes there is simply a build up of fabric softener residue on them that stops the dryer from heating up. Clean the sensor with an alcohol wipe.
Hope this helps and don't forget to get all the lint out of the dryer before putting it back in service.
Posted on Jan 27, 2008
I cleaned this sensor close to the exhaust outlet...Now it works GREAT!!! Kemnore Soft Heat 22 years Old.
Posted on Apr 03, 2009
We replaced both thermal fuse and the two pack of internal thermostats and the dryer runs without heating. . . which means that our problem is only 1/2 fixed because before we did this, it wouldn't even come on. Found on www.repairclinic.com that if the unit runs but doesn't heat (on an electric model) then it could also be the heating element, wiring that has burned out part but not all of the wiring, or one of the two fuses or circuit breakers from the house (dryers use 2) was blown or tripped. After checking these things, we think we've got to replace a heating element. ugh
Posted on Feb 08, 2008
    President:
  • 1,314 Answers
Remove the back panel off the dryer on the side of the pan holding the heating element you will see a small disc with two wires on it thats the thermal fuse if your going to check it with a meter remove one wire first its a non resetable fuse
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer won't heat up,runs no heat
IS YOUR BURNER COMING ON /IF NO REPLACE THE FUSE IN THE BACK ITS CALLED A OVER HEAT LIMIT FUSE IF THAT DOES NOT WORK REPLACE YOUR CERAMIC IGNITOR /1st UNPLUG THE DRYER /THEN UNSCREW TWO MOUNTING SCREWS THEN UNPLUG ONE ELECTRICAL CONNECTOR THESE ARE EASY REPAIRS YOU CAN DO IT /GET YOUR PARTS FROM A LOCAL PARTS SUPPLIER.
Jan 17, 2009 | Whirlpool Dryers
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The dyer works, heats up but the door keeps popping out and stop
REPL/ THERMAL FUSE LOCATED IN REAR (IF) LINT SCREEN ON TOP// OR LINT SCREEN INSIDE DRYER REMOVE METAL HOUSING WERE LINT SCREEN GOES INTO AND BEHIND THAT IS THERAML FUSE WHITE IN COLOR 2 RED WIRES CONNECT TOOOO......
Nov 29, 2008 | Whirlpool LEN2000PW Dryer
Takes too long to dry clothes
Check the dryer venting from the dryer to where it exits the house. It is most likely coated with lint and needs to be cleaned out.
Jan 08, 2008 | Dryers
Kenmore 64942 Electric Dryer Logo
248 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
