Phillips DVDR3320V 'disc unknown' error
When I insert a disc, retail or blank, it often comes up with 'disc unknown'.  I have previously been able to burn to the brand/type of blank discs I have (using this machine), but now cannot play them anymore.  I bought the machine new not more than 18 months ago, and have not used it to burn DVDs more than a dozen times.
  • Anonymous Jan 16, 2009
    when i put in any disc rental or burnt one it comes up with unknown disc. it does seem to play dvdrw that have previously been recorded on by the same machine.
Hey there,
Have you tryed different types of DVDs. You might need to buy DVDs that say DVD RW.
Posted on Jan 27, 2008
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
Phillips DVDR3320V Vidoe Recorder plays the first two or three minutes of the disc and then repeats it again and again.How do I get it to play the whole disc? Will this model play NTSC recorded discs?
HI,
Please let me know if you face this problem only with that 1 disc which you are trying to play or is the problem same with all the discs?
Sep 15, 2008 | Televison & Video
Trying to record to disc from VHS After recirding 8 copies, it now reads "Unknown disc, Please check disc" This is a Go-Video VR3845 Unit.
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
Apr 08, 2011 | GoVideo Go Video VR3840 DVD Recorder/VCR
Trying to copy VHS to Disc-Says"Unknown disc"
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
Not allowing to record.Comes up with disc error
if you use a phillips brand audio recordable blank it should be no problem
Feb 24, 2010 | Philips CDR775 2-Disc CD Recorder
DVD won't recognize the disk message below
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
Nov 26, 2007 | GoVideo VR3845 DVD Recorder/VCR
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
GoVideo VR3845
I too have this problem, will read regular CDs but no DVDs. I get the sme message, then the disc ejects. Is there a RESET function?
Jun 30, 2007 | GoVideo VR3845 DVD Recorder/VCR
Televison & Video Logo
526 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
