Question about Maytag Atlantis MAV6000 Top Load Washer
I need to replace the lid switch on my machine
Where do I start and how difficult is this task on a 1-10 scale? Thanks
On a scale of 1-10...10 being hard it's a 2. Pull the three screws out of the back of the control panel. Tip the panel towards you slightly and lift up. Gently set the panel aside. Disconnect the plug for the wires to the switch. Raise the lid about 3/4 of the way. Slide the switch towards the front of the machine and lift up. Reverse the procedure to re-install.
Posted on Feb 02, 2008
  • 770 Answers
Post your email here i will send you the service manual
Posted on Jan 27, 2008
On final spin,motor works but not spinning out. Acts like something is jammed up
o . Hello,
There are several reasons that a washing machine won't drain or spin. The causecould be something as easy as a clog or something difficult that will need alicensed repairman. Start with the simplest possible cause and work down to themore difficult causes.
INSTRUCTION BELOW
· A washing machine won't spin if the watercan't drain. Check hoses for any kinks or clogs that may prevent the water fromdraining. If a hose has kinks, try to straighten out the kinked hose. If itcan't be straighten sufficiently, replace the hose. If hoses are not kinked,check for clogged hoses. This can be done by using the screwdrivers to removethe hoses and looking for clogs or running a water hose through the cloggedhose to remove the clog. Use the rags and bucket to clean up the water thatcomes out of the hoses when they are disconnected. Once the clog is cleared,put the drain hose back into place. The washer should drain and spin now if aclogged or kinked hose was the problem.
2 If the washer still won't drain or spin,check to see if the lid is not closing all the way or if the lid switch is notclicking into place. Close the lid and make sure that it closes all the waydown. When the lid closes, the lid switch should click. If there is no clickingsound, then the switch may need to be replaced. Follow manufacturer'sdirections for replacing the switch. If the lid does not close all the way,visually check for signs that the lid is bent. If bent, try to bend it backinto place.
3 Loose or broken belts could also prevent awashing machine from draining or spinning. Pull the washer away from the walland, using the screwdrivers and wrenches, remove the back panel. Using theflashlight, visually check for any broken or loose belts. Replace any broken orloose belts. Although replacing washing machine belts is difficult, anyone whohas replaced belts on a car, lawn mower or even a bicycle chain should be ableto accomplish the task.
4 Another possibility for a washing machineto not spin or drain is the pump. With the back panel still off the washer,check the pump with the voltmeter to ensure that the pump is getting power. Ifthe washer is getting power, turn on the washer and listen to find out if thepump is running but the water is still not draining. It may be necessary toremove the pump and clean it or to replace the pump with a new one. Once thepump is replaced, turn on the washer to determine if it will now drain andspin.
5 If all of the above steps fail to produce awashing machine that drains or spins, then it is time to call a professionalrepairman. Use the screwdrivers and wrenches to replace the panel on the washerand push it back against the wall.
Please rate four thumb.
Thanks and good luck.
Sep 13, 2011 | Washing Machines
Machine is stuck on 23 and wont drain a small amount of water. it attempts to run. It is on the wash cycle. No error codes
ChallengingInstructions And Things You'll Need:
  • Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall..
Thanks and thanks for visit good luck.
Jul 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Machine wont spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
  • rate this.
    Dec 27, 2010 | General Electric WHDRE526EWW Top Load...
    Washer will not drain. All normal solutions do not work. There is a relay (697811) that may be the cause, also drain solenoid is likely. does anyone know the value (ohms) of the these coils? Thanks for...
    INSTRUCTION BELOW
  • your ratting is helpful
    Dec 26, 2010 | Washing Machines
    Supra topload automatic sw 7bh2p doesn't spin
    INSTRUCTION BELOW
  • Thanks and good luck.
    My idesit washing machine wont drain and spin?
    INSTRUCTION BELOW
  • Please remember to rate this solution fully.
    Wont drain has cade e20 flashing
    INSTRUCTION BELOW
  • thanks and thanks for using fixya
    Oct 03, 2010 | Frigidaire Affinity ATF7000E Front Load...
    My kenmorre 41742042100 will not drain
    INSTRUCTION BELOW
  • thanks and good luck.
    Oct 03, 2010 | Washing Machines
    Will not spin
    INSTRUCTION BELOW
    Oct 02, 2010 | Maytag Legacy Series Top Load Washer
    MY WASHING MACHINE WILL LOAD THE WATER BUT THEN IT STOPS (WONT SPIN)
    INSTRUCTION BELOW
  • thanks.
    Oct 02, 2010 | Maytag Washing Machines
    Maytag Atlantis MAV6000 Top Load Washer Logo
    54 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
