Fixing ipod My Ipod turns on but the screen is empty and wont boot up
Alright. I have an 80 gig new classic that gave me the " white screen of death". Un-plug it from your computer. Its not broken. It will still play music on your computer as well as through your headphones. Keep trying to turn it off and on. At first, nothing will happen. Keep trying until it goes dark. turn the wheel and all your pixels should be restored. If not, keep it on until it goes dead, then plug it back into your computer. Mine got fixed after one try of the first solution I suggested. Good Luck.
Posted on Jul 17, 2008
  • 77 Answers
This sounds like the "white screen of death" that some ipods suffer. Try plugging in your headphones and see if you can still hear the clicks when turning the clickwheel, aslo if you can get a song to play.
There are a number of different solutions that people have done to solve this.
One is to keep turning the ipod on and off until the battery wears down completely, then reconnect to your PC or wall A/C adapter.
Posted on Jan 30, 2008
Ipod wont turn on
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Apr 16, 2013 | Apple iPod touch
Why wont my ipod touch turn on i turned it off and it wont come o
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 22, 2009 | Apple iPod touch
My ipod wont turn on
If your ipod won't turn on then try these.make sure you click on the blue links for more info.
Make sure the Hold switch is off
  1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
ts1383_2.jpg To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
  1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
  2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
May 16, 2009 | Apple iPod nano
I tried jail breaking ipod and it wont turn on
Okay. if your jailbreaking is not working than it is something to do with who or from where you bought your ipod or the jailbreak program. If you are wanting to jailbreak your ipod i reaccoment the program HiJackThis it worked on my old ipod touch. But A word of warning. after i jailbreaked by ipod i dropped it and the screen cracked. they would not fix my iPod for the single reason that by "Jail Breaking" your iPod you break you warrenty and Apple will no longer repair it.
Feb 13, 2009 | Apple iPod touch
My ipod says www.apple.com/support/ipod My computer locked up and so my ipod disconnected before ejecting. At first it locked up bur I reset it. Now it shows a cross and tells me to go to...
im not sure if this will work, but, hold the menu button and the select button for about 8 seconds, or until the screen turns off, then u will get the ipod logo, and then it should boot up like normal
Jan 17, 2009 | Apple iPod MA446LL/A MP3 Player
80gb classic wont turn on
iPod reset is usually center and menu held for 5 seconds. Doing this should put it back into a normal behavior state.
Dec 15, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod not turning on or charing with computer
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If that is not able to fix your problem, contact apple or your dealer for more assistance or repairs.
If you need more assistance let me know. Good luck.
Jan 31, 2008 | Apple iPod nano
My ipod nano wont do anything
Did you try resetting the iPod? If the battery were dead then when you plugged it in, you'd still see something popping up on the screen. What's possible is that your screen got disconnected from the iPod logic board or otherwise got ruined. When you try turning the iPod on can you hear any noise inside? If you toggle the hold switch does it show the orange light? If you can't hear any noise and it doesn't show the orange light, your iPod's logic board probably died. You can get a new one off eBay and replace it if you're comfortable opening your iPod. Otherwise, you can sell the broken iPod on eBay for a decent amount.
Jan 06, 2008 | Apple iPod MA446LL/A MP3 Player
217 people viewed this question
 Grubhead
Grubhead
