Washer won't go into fast spin cycle
My washing machine is a Hotpoint and it will not go into fast spin cycle to spin excess water out. What could be the problem?
  • Anonymous Jun 07, 2008
    Our Whirlpool will not fast spin in the NORMAL wash cycle.
    It does slow spin in the other DELICATE, etc. cycles.
    Problem Solver:
  • 8 Answers
There are three possibilities, ONE: From the motor to the tub is a - Coupler. This works like a shim, like when it has too much force against the tub or some where. Sometimes these become worn, and that can slow down your machine, TWO: The clutch kit could be worn and dirty, OR, THREE: There is a resistance from the transmission or tub.
Posted on Apr 10, 2012
  • Ryan Smith
    Ryan Smith Apr 10, 2012
    This is a front loader no? if there is a door lock switch, and even when it tells you its locked it may not exactly tell the commuter in the machine. Another thing is the drain could be clogged. I would start with checking the drain motor. in the front before you start checking anything else. run the machine in spin empty. and see if it spins good.
  • 126 Answers
Check the motorbrushes. When the brushes get worn, the motor doesent get electricity to the communtator
Posted on Jan 27, 2008
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Washing machine seems to be washing ok but when it comes to the final rinse and spin the soapy water is pouring out of the soap dispenser on the front
this is happening because the machine is not draining the water away fast enough when going into the spin cycle. clean out the filter under the machine, this will solve your problem.
pallesappliancerepairs.com
Feb 04, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquaris machine is not engaging the fast spin function. When it comes to the fast spin in the cycle the machine goes dead. The machine was performing the fast spin until recently however the...
everything you have described points to a blocked pump,worth blowing down the clear pressure pipe from the switch end while your in there to make sure thats clear!
Jan 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Wet clothing
Does water run all the time or part of the time. Some water is injected during the spin cycle to remove excess soap and softener.
Dec 14, 2007 | Hotpoint VBXR1090D Top Load Washer
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
364 people viewed this question
Top Washing Machines Experts
