Question about Dryers
Frigidare laundry center model FLSG72GC
Pilot light is out on dryer, how do I re-light it, it is a stacked unit
  • 1 more comment
  • linda48 Jan 27, 2008
    Thnk you, I'll try your suggestion
  • alperins Jan 03, 2009
    I have an old  Gas Frigidaire washer/dryer model # FLSG72GCS9 The dryer stopped heating, and I wa told to replace the igniter and the tension braket on it. How do I do it and what would be the model number?
  • alperins May 11, 2010
    I opened the panel but still can't tell which part it is?
    President:
  • 1,314 Answers
It doesn't have a pilot light has a glow bar and a safety solenoid probably the glow bar needs replacing its on the side of the burner tube there is an slanted acess panel under the drier door
Posted on Jan 27, 2008
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
How to reseat the dryer on a fgx831cs dryer
Hi Amy, this is AP!
I understand you want to reset your Frigidaire gas laundry center, model FGX831CS. For this particular model laundry center I would recommend turning the breaker to the appliance off for 5-6 minutes, and then turn the breaker back on. This action will reset the laundry center completely for you. If you can provide additional information describing the malfunction or symptoms you are experiencing with your laundry center I may be able to provide more useful troubleshooting or an explanation.
Thanks,
Apr 03, 2014 | Frigidaire FGX831CS Top Load Stacked...
Washer won't drain and spin
Drain pump is cloged. What kind of washer is it . and you said stacked and laundry center. stacked is 2 seperate units and laundry center is one whole unit with both so whatcha got?
Feb 17, 2013 | Frigidaire Washing Machines
Does Frigidaire combo Washer/Dryer have any fuses inside cabinet ?
Hello - Generally speaking, Frigidaire laundry centers do not have fuse. The unit has a thermal limiter usually located in the dryer.
Oct 21, 2012 | Frigidaire FullFGX831C Size Stack Gas...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
203 people viewed this question
Top Dryers Experts
