Question about GE WSXH208A Front Load Washer
GE WBVH6240 Have GE WBVH 6240, historically, aside from "violently" shaking during spin mode has worked well - it's 18 months old. During "stain wash" mode, the washer would not go into spin cyle. While it will fill and rinse, when it attempts to go into spin, it stops functioning, and actually sounded like it was making a "sparking" noise in bottom right hand side internally and the motor/pump sounded like it was humming. Obviously, it's out of warranty, any suggestions would be appreciated before I drop a couple hundred bucks on repair - GE wants $80 just for a tech to walk in my front door which doesn't include any time or materials. Is this going to get expensive?
  • jeffward Jan 27, 2008
    Thanks for the quick response, and most likely a solution as there was a tremendous amount of lint, coins, etc... in there. Interestingly, my manual says nothing about this. New manual on GE's site indicates that it can be cleaned but does not provide instructions.
    Anyway, quick question, when the filter is replaced does the tray with holes go toward the top or the bottom?
    Genius:
  • 1,554 Answers
Disconnect power to machine,
Drain all the water you can.
Remove the bottom access panel ( 3 screws on bottom plate)
open the large plastic filter in center
have a tray and towels to catch the water,
remove all clogging material,
look in with a light and turn the pump , it should turn freely.
Posted on Jan 27, 2008
  • Karl Whisenand
    Karl Whisenand Jan 27, 2008
    once the filter is tightened it will face the pump to keep out objects from the impellers.
  • Katie Sullvian Feb 01, 2013
    This advise just saved me $150. Karl Whisenand, as far as I'm concerned, you're my favorite thing about the internet! Thank you!
2 Suggested Answers
SOURCE: GE WBVH6240
All,
There are three screws under the plate beneath the door. Remove these three screws and remove panel. Immediately you will see a removeable plug about 2 1/2" in diameter made of white plastic. This is where your problem lies (or at least one of them). CAUTION - before you remove this plug, put a bucket under it because water will come out. After you unscrew the plug completely, pull it out toward you. You will no doubt find many items that washed out of your cloths. I found legos and coins tangles up with strigs and lint. The entire area was completely plugged. The coins were probably the source af the stains we had on our cloths as they were all black from the water and soap.
The pump on mine burned out and I am trying to replace it. Then I will sell this junker.
I hope this helps some of you. Please advise.
Posted on Aug 11, 2008
Ge WASHER WHRE5260E shakes violently and makes loud noises during spin cycle
the cloths in the washer needs to be ballance... too much load on one side
Nov 14, 2010 | GE WHRE5260E Top Load Washer
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Shakes Violently
run it with the top access panel open and watch,
while you are there try out the suspension ,
you do it like an old car push it down , push to sides etc .
it should resist and return well. no bounce. tight.
May 15, 2008 | GE WBVH6240F Front Load Washer
GE WBVH6240
All,
Mar 23, 2008 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
413 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
