Question about SanDisk Sansa e200 MP3 Player
Submenu Not Working
I have trouble with my submenu button. I can't use it to move back to other menus. I was in music and keep trying to get back to settings, etc., after about 10 minutes of trying, I finally got back to the menu and selected FM to see if I have good reception. Now I'm stuck in FM and can't get out. Pushing the submenu button just takes me to radio options. If I push the left button, it goes back to the selected FM station. Pushing the left button twice just takes me to volume.
  • 35 Answers
If your gadget is still under warranty, return it to where you bought it. One of the keys are stuck and their technician will just disassemble and reassemble your mp3. But if you know a liitle electronics, you can do it yourself
A Simple Thanks is Good enough
Posted on Feb 15, 2008
6ya staff
SOURCE:
How do i turn on shuffle
Hi Nonya Buisness,
  • Music Submenu
To enter the Music Submenu, press and hold the OK/VOL button for 3 seconds.
AB Repeat
When you select "AB Repeat", you will be returned to your file, and "A-" will be displayed on
the playback screen. Briefly press PLAY to set the "A point" and "-B" will be displayed,
briefly press PLAY again to set the B point, and begin playing you're a-B selection. The icon
will change to "A-B". If you press PLAY again, you will cancel A-B Repeat.
Repeat
To adjust your repeat mode, select "repeat". You can select Sequence, repeat one, repeat
all, shuffle, or shuffle and repeat
**Pressing M will lead you to top menu.
http://www.eclipsemp3.com/180G2.pdf
Mar 02, 2014 | Eclipse 180g2 4gb mp3 music/vid
How do I switch my eclipse 180G2 mp3 player from shuffle to normal?
No trouble, here's how to turn SHUFFLE on or off:
Music Submenu
Repeat
To adjust your repeat mode, select "repeat". You can select Sequence, repeat one, repeat all, shuffle, or shuffle and repeat.
Manual
Product page
180G2 Series Eclipse Media Players and Tables
Feb 11, 2014 | Eclipse Audio Players & Recorders
Reset language
Press the MENU button, select the wrench icon, then select the seventeenth item on the submenu. I know it's a pain when you can't read the language it's currently in. All camera makers seem to have trouble understanding that the main reason someone wants to change the language is that the someone can't read the menu.
If you're not sure you've got the right item, you can always go into each submenu in turn. If there's an option labeled "English," select it. If not, just back out without changing anything.
Dec 18, 2013 | Cameras
Canon mx 410 fax answers voice calls
I have an MX870 with the same problem - fax picks up during a voice call and I can no longer hear the caller. As with everyone else, the problem is intermittent and not replicable.
I have tried tel priority mode and fax priority mode (from the phone/paper submenu under physical Fax button) and all the various RX receive setting under Fax Settings submenu of the physical Settings button.
But I have a new possible solution. I only use the fax for outgoing -- for some time now I have been using K7.net for incoming faxes which delivers faxes to my email. That way I have a dedicated fax number, never miss an incoming fax while on the phone, and I have all faxes in electronic form as well.
So, my new idea was to set the MX870 to DRPD (distinctive ring pattern) receive mode (from the phone/paper submenu under physical Fax button). Since my phone service through Xfinity/Comcast does not offer DRPD, I am hoping that the MX870 will NEVER pick up a fax.
I will keep you posted as to whether this works.
Jan 13, 2012 | Canon Pixma MX410 All-In-One Printer
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
In Explore context menu open with option has no submenu options
Submenu under openwith depends on types of extensions you are trying to do open with. For example, pdf file will have the extension Acrobat reader and internet explorer, because pdf file has been successfully opened with those programs previously.
First try to open the program using open with and next time it will show you the submenu to open with.
May 16, 2010 | Microsoft Windows XP Professional
How do I set it to play random songs?
While a file is playing you can enter the Music Submenu by pressing the “M” button briefly. The Music Submenu allows you to adjust your repeat mode, amongst other things.
The Repeat Menu allows you to set your repeat mode. Choose from Normal, Repeat One, Folder, Repeat folder, Repeat all, Random, and Intro.
Choose Random.
Here is an online version of the manual, incase you have any other problems you want to read about. http://www.eclipsemp3.com/CLD2manual.pdf
Feb 27, 2010 | Eclipse CLD2 MP3 Player
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Help!
To the op, you might need to switch it back to MSC mode from MTP mode. You might not be able to play the DRM protected music in MSC mode, but you'll be able to access all the rest.  1. With the unit on and not attached to a computer, press the Power/Menu Button briefly once or twice so the menu is shown.
2. Scroll down to Settings then press the OK button (round shaped, centrally located) to enter the submenu, next scroll down to the USB option and press the OK button to enter its submenu, highlight MSC, then press the OK button. After the MSC option is enabled, hold down the power/menu button until the unit shuts itself off. Now plug it back into the computer.
(Now you should be able to find some files to delete. Enter any folders/directories if necessary to find files to delete.)
Unless you have bought and downloaded to your unit protected music from online music stores, you might find it more useful to keep the MSC setting instead of going back to the MTP setting.
To the second poster, you likely downloaded a scam file.  It's sometimes disguised as an mp3 file but it's really likely to be a wma file that has web links that automatically execute when played in Windows Media Player.  Your mp3 player errors when accessing it. Just delete the suspect file(s).
Otherwise you could reformat it or maybe upgrade the firmware. Right-click its icon in My Compter for a popup that allows a format.  Use FAT32.
Sep 01, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
