Question about Sony PlayStation Portable (PSP) Console
PSP Joystick is sticken
You can move joystick side to side with no problem, but to move it up and down it is sticking. It's all most like it is catching on something
  • mouldmaker Apr 06, 2008
    also have a psp where joystick goes side to side and forward but not back.
    PSP unit is only 2 months old
    HB
  • Anonymous Jun 18, 2008
    joy stick is sticking
    Scholar:
  • 72 Answers
Remove the back of the case, remembering there are screws under the battery. Remove the UMD drive, and then remove the Dpad-analog board, flip it around making sure you only touch the edges of the board and are on a tile floor to minimize static electricity. Use a good aresol solvent based electronics cleaner and hose it down. See if it works good then. If not, you may have to replace the analog jog switch.
Posted on Jan 27, 2008
When i try to play any game on my psp the joystick keeps moving down....and i took out the joystick and still does it...i play another game like final fantasy 7 on my psp that doesnt use the joystick and...
if you are facing problem in psp then just don't worry........... you can fix it with the help of repair guide you can download it and solve your problem easily...........
i will give you the link to download i hope it will solve your problem
Click Here to download
Dec 08, 2010 | Sony PlayStation Portable (PSP) Console
Ive got a psp and the move button is sticking it always in the down position
If this is only happening in games, it's a problem with the joystick assembly. It's pretty common on the PSP for this part to wear out and characters [or menu options in games] will start scrolling by themselves. Replacing the part will fix the PSP up. Check the following website out -- they sell the joystick and perform replacement repairs:
http://store.richspsxparts.com/pspanstasre.html
Nov 17, 2009 | Sony PlayStation Portable (PSP) Console
Joystick problems
The only way this can happen is if you have damaged the joystick function area.You have to change the joystick and put another one.
Jul 22, 2009 | Sony PlayStation Portable (PSP) Console
Psp joystick
try replaceing the stick but else i would take it into a store and get it fixed
Feel free to Email me: Thomashedderwick@hotmail.com
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp moving by it's self still.
If you take the front cover off your psp then the joystick/analogue stick is attached onto it. This can easily be taken apart for cleaning. If once you have done this it is still moving by itself then check the rubber connector that connects the joystick to the psp (in metal bit under joystick) this may be dirty, if so then clean this. If everything seems clean and it still moves by itself then replace the joystick (can be bought from www.consoleparts4u.co.uk) this is an easy task once you have got the front of your psp off.
Hope this helps
Mowcius
May 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
the joystick, sticks and moves on its own
Apr 19, 2008 | Sony PlayStation Portable (PSP) Console
Psp moving on It's own
when you replaced the joystic was it just the little top part or the whole joystick?
Apr 17, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
well psp were built to have its own joystick, other joystick are usually generic versions, so the chances of them being faulty for psp are high
Feb 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
