Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Wasehr won't power up
Brand new Aqua Smart. It powered up for the first tim, and we tried tojust run a load without clothes to make sure it was clean and working. Power went off and now it will not power up. The outlet has been checked and is fine. We did unplug it several times for several minutes and still no power.
  • marisminton Apr 03, 2008
    same problem, not new
    President:
  • Fisher and P... Master
  • 2,651 Answers
Brand new???? call an authorized servicer. as long as your electric is good .all you can do
Posted on Feb 27, 2008
Fisher and paykel aqua smart washing machine alarms to indicate imbalance during rinse and spjn cycle even when no clothes in it. Have checked that it is level.
when using a level to set the machine up use it on the tub and not the lid
the unbalance can be from a suspension isolator that has failed and dropped the tub to one side
Feb 04, 2017 | Fisher and Paykel Washing Machines
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
Aqua smart has power won't start cycle
hi, first thing i would check is the door is locked properley if ok then check filter if has 1 if this ok then check drain hose at the back of the washer make sure it's not blocked hope it helps
regards
shaun
Nov 18, 2011 | Fisher and Paykel Aquasmart wl80t65c
F&P machine is a top loador, not sure what model,( it has no agitator )and is approx 5yrs old. cold water has been used. it now needs to have a hot wash, what do you recommend to clean the machine...
Hi just read your posting.Depending what country you are in it is either an AQUA SMART OR AN ECO SMART.Try a cycle with the efficiency button turned off and selecting a warm wash on normal or heavy duty or regular.This will make the machine wash the clothes with more water.Please reply on how you got on or for further help.Looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
