Question about GE 24 in. GSD4020Z Built-in Dishwasher
GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Can anyone help me?
  • tbrief Aug 18, 2008
    I have the same problem- how do I find where you answered this?
  • robert samples May 11, 2010
    may be whats your promblem
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
SOURCE: GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Does it sound like it is trying to drain or is it just silent?
Posted on Jul 27, 2008
landsend
  • 1066 Answers
SOURCE: GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Posted on Apr 12, 2009
SOURCE: GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Posted on Jan 21, 2010
iwillfixforu
  • 619 Answers
SOURCE: My GE Potscrubber Dishwasher doesn't spray water
If you turn it on and hear a slight hum after water fill the motor is locked from non use. You will need to remove bottom panel and with power off you will see the motor right in the middle near the front. This is called a side winder motor because of how it sits. There are some blades you can turn to unlock the motor. Once the motor breaks loose which you will be able to tell when it does, turn power back on and let run thru complete cycle with heat dry in the off position. GE are about the only ones out there that will do this and it is usually from lack of use. Hope this helps.
Posted on Feb 23, 2010
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
When the water drains at the end of the cycle, water drains from the bottoom of the dishwasher, around what looks like an actuator arm? not exactly what the model # is all i know is it is a GE potscrubber...
Hi, I have seen this a lot when I did maintenance work for apartment communities.The part to fix this depending on modle was $85-$125 six years ago, I would just replace it.
Mar 05, 2011 | GE Dishwashers
GE Potscrubber will not drain or cycle.
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Dishwashers
My GE Potscrubber 1200 cuts on perfectly and
probebly you dont have enough water coming in start the dishwasher,when it starts washing dump a bucket of water in the tub.if it starts moving replace the intake valve
Feb 26, 2010 | GE Dishwashers
Jan 21, 2010 | GE Dishwashers
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
Jul 08, 2008 | Dishwashers
GE Potscrubber Disshwasher GSD700G, wont cycle
Most washers do not fill they spray the dishes. When enough water has accumulated in the bottom a float switch shuts off the water and turns on the pump to remove the water. If the pump motor does not remove the water the cycle will not continue but the timer will. There may be something clogging the pump and resulting in an overload condition for the motor. This would account for the smell. A pump may turn freely when you spin it by hand because you cannot spin it fast enough by hand to determine if the pump is obstructed. Does the cycle drain the water? If the cycle stops and there is water in the bottom not being pumped out then you should look at the pump and the motor to determine problem.
Jan 19, 2008 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwasher
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
GE 24 in. GSD4020Z Built-in Dishwasher Logo
652 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
