Question about Soundstorm F200.4 Car Audio Amplifier
I dont know how many watzz is my amP!
My soundstorm amp says in the front 200 w x 4 .. so how many watzz is that?? is a 4 channel amp btw.
    Sergeant:
  • 203 Answers
200 X 4 does mean 200 watts times 4 channels. In other words each channel pushes out 200 watts. I believe u have a total output power of 800 watts but check with ur manual and if u do use that much power make sure you check for overheating, specially if its used for bass. Soundstorm amps cant take much of a beating so be careful.
Posted on Jan 28, 2008
FUC% the protection light
i had a similar problem with my amp (although a different brand). Check you ground connection and make sure it's not grounded to metal with paint covering it. This is NOT a solid ground connection. You must remove the paint then reconnect it. Without a solid connection to ground, it cant run for very long without going into protection mode. Hope this helps
Jul 27, 2009 | Soundstorm Force F2800 Car Audio Amplifier
I dont know what my amp wattage is
It's a 200 watt amp. RF for Rockford Fosgate 200 for 200 for 200 watts and 2 for it being a 2 channel amp.
Jun 27, 2009 | Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2
For a 1ohm load it's positive to positive and negative to negative run 1 wire from one speaker to the other. Positive to positive neg to neg. Then 1 wire from the speakers to the amp. The amp will have + - + - on it's inputs for left and right speakers (if stereo) Use the outside positive and outside negative. If there are any switches on the amp that say "mono" "stereo" switch to "mono". Hope this helps
Jun 20, 2009 | Soundstorm 500.2SL Car Audio Amplifier
I NEED DIRECTIONS ON HOW TO CONNECT MY AMP TO MY CAR
We'll start with powering the system up. YOu will need to run your power wire from the battery. It must have a fuse just after the battery. Run the negative to the chassis of the vehicle. On the back of the radio, there will be a blue wire labeled remote/antenna. This wire needs to be connected to the amp. This is what turns it on and off when you power up the radio. Next you will need to run the RCA cables from the back of the radio to the amp. Now you are ready to hook up the sub woofers to the output side of the amp.
Mar 27, 2009 | Soundstorm 500.2SL Car Audio Amplifier
Aux input on Soundstorm amp
If the amplifiers have RCA jacks, you can use an adapter cable to go from the headphone jack to the RCA inputs on the amp. If you're in the U.S., Radio Shack will likely have what you need.
Jun 30, 2008 | Soundstorm 2F400 Car Audio Amplifier
My amp!!
okay, 200 x 4 means 800Watts now that should be the peak RMS which is how it regularly works "STABLE" should be 400 or 100rms per chanel, find speakers of 100 rms to get e clean sound wave. If you can bridge it get you two 200 rms speakers.
Jan 27, 2008 | Car Audio & Video
Soundstorm F200.4 Car Audio Amplifier Logo
112 people viewed this question
Top Soundstorm Car Audio & Video Experts
hoyzee1
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
