Eiki LC-xnb4m computer connection issue
I just purchased this unit and cannot get it to recognize my computer. If I attach the 15 pin connector / DVI-I, it makes my compuer screen go black, and navigating into the menu on the projector shows no signal. When I attach a s-video cable or the USB 2 cable there is no change at all, and the signal is still not acknowledged.
  • clevymd Sep 24, 2008
    I have a Dell Inspiron laptop, very new. I plugged in the Eiki LC XNB3 and the computer screen was projected for a few seconds then stopped and now I can't get it to project my computer at all.
I actually fixed it myself--I found another site that said for Dell systems, you need to hold down the Fn button (bottom left) and push F8 and then it recognizes the projector. Solved the problem immediately!
Posted on Sep 24, 2008
  • 261 Answers
Sometimes you have to change resolutions on the computer display to a lower resolution for the projector to recognize it. try 800x600 first and then make sure your inputs are activated in the menu. sometimes this can be a problem. but most projectors auto recognize when something is plugged in. Let me know if this helps you. Thanks Jay
Posted on Jan 31, 2008
Repair wire from signal cable is disconnected or broken (15 Pin D shape Connector)
Soldering usually. Some connnectors were prefabricated with rubber being injection moulded. Your best bet is to purchase a 15 pin D connector and change the old one by soldering.
Mar 19, 2014 | ViewSonic E70f 17" CRT Monitor
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Giving message on laptop that says, "projection mode disabled"
try to use a full wired VGA cable, so the laptop can recognize the external display/ projector by the ID pins.
Many laptops deactivate external display ports to save energy
Mar 18, 2010 | Eiki LC-XB15 Multimedia Projector
Projector remote
go into the menu under settings. should find lamp hours under there. as for the remote, try
Nov 10, 2009 | Eiki LC-X1100 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
My eiki LC-xnb4m will power on but shuts off after about 60 seconds. It doesn't shut off just drops the input signal (audio and video) and the fan kicks on heavy for a few minutes. Then...
may be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Jul 01, 2009 | Eiki LC-XE10 Projector Multimedia...
EIKI LC-XNB3 Projector - Does not recognize any Video Inputs
there might be a bad connection between the input board and the main board. There are different connectors ( white) between them, that might be damaged during portable use
May 24, 2009 | Eiki LC XNB3 Multimedia Projector
New projector. which cords do I need?
laptop, vga. dvd, composite or s-video, and audio. gaming console, composite or hdmi, if you have it.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
The projector switching off after 30 seconds
check the following :
1.does the lamp glow u get the connected image
3.if yes does the screen show temperature or overheat
4.if yes then one of the cooling fans do not work properly & hence the unit turns to standby & goes into protection
if no 1 does not happen, then check the lamp physically,it should not show melted or breakage.
if the lamp seems ok, then the ballast is defective!
Feb 08, 2009 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
413 people viewed this question
