Question about CyberPower 1350VA UPS w AVR & LCD (CP1350AVRLCD) UPS System
UPS Failure My UPS up and died today, no warning, running on wall-power, just *blink* and my system was off. After unplugging everything from the UPS, I turned it back on. It starts up normally except the fan does not turn on (as it usually does for a second). After about a minute, the LCD goes dark as it normally would (except the backlight stays on) and *beep* *beep* *click* when the LCD blinks which repeats indefinitely. I tried another wall socket and the same thing happens. Inside the UPS, the transformer core is rusted on one corner and popped open (sorry, pathetic camera phone): http://img150.imageshack.us/img150/1588/413023260108co5.jpg Perhaps a spark occurred here. Thank you for any assistance you can provide
  • 2 more comments
  • tamarazoe Jan 27, 2008
    I doubt it's just a fan failure. It doesn't normally run the fan while on grid power so it shouldn't be simply overheating.
    The computer works fine (thankfully). I am currently running off of a simple surge protector now.
    The fan I was referring to is a tiny 20mm fan inside the power supply.
    It's possible I confused you by referring to the LCD. The UPS I am using has a small LCD on the front of it to give load information and such.
    Thank you for the suggestion but I am interested in repairing my $200 UPS at the moment. A surge protector will not see me through a storm without downtime nor cleanly shutdown, risking software as well as hard drive complications.
    I forgot to look clearly at the fan connector but I believe it was soldered on. I could desolder it and then check or replace it. I'd love it if it were the fan, it would save me from having to ship this unit back to CyberPower.
    However, I'm looking for possible other problems. The appearance of the transformer bothers me as it suggests an arc occurred. However, no PCB or anything was blackened (which was one thing I was looking for opening it).
  • Anonymous Mar 19, 2008
    I removed the battery from mother board and the ups fan start working.
    After a few seconds the monitor give the folowing:
    cpu fan failure system shut off in 5 seconds.
    Genius:
  • 1,067 Answers
Get new fan in if its not working
Posted on Jan 27, 2008
  • 1 more comment
  • Anonymous Jan 27, 2008
    might have to re do your xp install when power droped it screwed it up repair it put xp cd in boot into it
    i got ya proably just fan went out on it not sure if u can buy one or not i use monster power strips reg surge is fine long as bios is set to stay off after power failuer in storm u will be ok just not directto wall hd700 monster with clean power will protect u up to 150 000 thats 70 bucks at best buy
    maby overheated cuse fan isse least put fan bye it on low ok keep it cool those things run hot now days computer if it shuts down wont hurt it back in p3 days it would sumtimes reset bios but i understand gotta keep it cool breathable off carpet 500 wats waiting for the power out in that upc so get fan on her
6ya staff
SOURCE:
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
Battery b/u squeals after unplugging everything from it and have also uplugged the unit from the wall
Hi Robert,
The UPS will beep/squeal if the power isn't turned off to it before it is unplugged from the wall. But the other thing that may be causing the noise is a bad battery. Replacement battery price is $26.00.
Reply or call if you need more help with this -- 407.380.9200
Sep 20, 2013 | APC (BE500U-WEB) (BE500UWEB) UPS System
Not Working During Power Outage
Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
Sep 04, 2013 | CyberPower Computers & Internet
I have Numeric 1000 Hp Digital Ups .now i have a problem With it .Always it is giving short beep sound, and displays shows "Warning 22".Battery back up is also not giving. During power failure instrument...
Replace the batteries in the UPS - that's your problem. Everything should work after that :-D
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • [email protected] • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 24, 2013 | QVS NetStar (UPS650A) UPS System
Yesterday and today one of our Smart-UPS 1400 powered off and 2 of our servers along with it. What would cause this?
may be power to the UPS went off or was not within permissible limits, hence the ups run on batteries until they were completely discharged, the servers went off because they are supplied by this ups. check the power supply to this ups, somebody could be switching it off accidentally. try to sitch the inpu power to the ups to see whether the batteries are okey
Dec 15, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
CyberPower 525SL Failure
The erratic behavior and beeping could indicate that the Gel battery inside your UPS needs to be replaced, and is usually less expensive to replace than the entire UPS. You can remove the battery and contact a local or online source for a replacement. I replace mine through a local automotive battery supplier, and it' never cost me more than $20.00.
May 24, 2008 | CyberPower 525SL (CPS525SL) UPS System
Low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
Oct 30, 2007 | APC Back-UPS ES 350 - UPS ( external ) -...
IBM OP500 Uninterruptable Power Supply
http://www.tripplite.com/support/manuals/manuals_bymodel.cfm?modelID=11 that is the link to the manual you need. It sounds like your UPS is not turned on correctly. You must press and hold the on switch. Make sure the AC sign wave is lit solid not blinking, the battery should not be lit as well. If the battery is yellow, that means you are running on battery, if it is red that means the battery is low.
Jan 23, 2007 | IBM Tripp Lite Internet Office 500...
CyberPower 1350VA UPS w AVR & LCD (CP1350AVRLCD) UPS System Logo
688 people viewed this question
Top CyberPower Computers & Internet Experts
Paul Bade
klasspappa
Level 1 Expert
 Mike M
Mike M
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
