Toshiba D-R2su Recording Error
My Toshiba DVD/Recorder will not record to my DVD-R nor will it allow me to use a disk DVD cleaner to clean the lens. It will play DVDs just fine, but will not let me record. It stops after 40 seconds and says Disk Error check Disk, may be damaged or dirty. These are all new disks that I just bought. Can you help?
  • woodybrosnan Jul 11, 2008
    it won't load dv-r's.
  • flashman07 Dec 05, 2008
    I have the same problem. Put the Toshiba in the closet.
I've got it!!!!!!!
Although this is an old thread, recently I had an idea about my own Toshiba DVD Recorder. Same problem all over the grid when it comes to this model and hopefully some of you who currently have this problem will find my post and once again be using your unit as I am mine. The problem is so simple you'll flip! This Toshiba DVD Recorder device is exactly what we're all using as DVD burners in our home pcs, just a Toshiba in this one though, I had an LG multi-writer, dula layer, blah blah blah and when I opened up my Toshiba unit, saw how the screws go into the sides, the IDE connector is EXACTLY what we will find in our PC's, the Toshiba jumper pin was set to MASTER and like modern day DVD or CD drives, we no longer need to connect an audio connector to get what else, but audio.
Early today I looked closely at my LG replacement unit, saw that the tray is more shallow than the original Toshiba one. Most of you know why the tray is so deep? Because with this unit one can use the cartridge-style DVD-RAM disc but since a PC's dvd tray is not as deep, I just ripped into the case and used the actual ram disc without it. The Software Version for the Toshiba is ZN10 and the DVD Drive Software WAS 1309. The drive software will change to whatever your newest PC-DVD recorder will be. In my case I had a 2006 LG and the Toshiba was a 2004 but irrelevant anyway. One thing you must remove from a PC type DVD recorder/burner, is the front access door and the surrounding trim since inside the Toshiba home unit, no door or trim attached to the Toshiba's DVD unit but of course you would notice that the silver door opens when the eject mech. is actuated.
For 2 years my Toshiba was malfunctioning, would read older discs I had recorded and finalized, some of the other discs I had recorded some things on but didn't finalize, I was able to do so today. The problem I have heard about these Toshibas is that their laser units are el cheapo but kind of ticked me off because we paid $550 in 2004 for this thing and no hard drive of course. I do have an issue with my clock on this thing and maybe because we had it plugged in for the past 8 years or so. When off, nothing on the display, when turned on the display shows the time and then it blanks out and we can only see the elapsed time, counter etc. Not that it matters but don't think I'd ever buy another Toshiba device anyway now.
Hope this has helped and trust me here, if your unit still powers on and you keep seeing the disc read error etc., you can probably find yourself a brand new dvd recorder for about 30 bucks retail and problem solved. Oh yeah, one interesting note and if I hadn't mentioned this now, some of you would realize it anyway, this unit will now record + and - since it's actually a PC recorder device LOL. Stupid Toshiba made this as only one type and that was -R but for the life of me, can't figure out why it couldn't have been both/all types. Really have to add about what I was reading awhile back too, some were advising that one couldn't use -RW types (rewriteables) but the issue actually stems from the laser and unit's weakness at reading better quality discs. The ones I had copied and finalized as WRITE ONCE (only) were really cheap ones and they have always worked. Prior to doing this unit swap I tried a store bought movie and it wouldn't read it at all, then when I did the hardware change, VOILA!
Posted on Jan 31, 2012
SOURCE: how to finalize
thank you
Posted on Jan 04, 2008
  • 4 Answers
SOURCE: panasonic DMR-ES10
Does the unit emit a groaning sound just before it fails? If so, then the drive spindle is the problem; the sound is caused by the slipping of the disk on the spindle. It could be contaminated with particles (dust, DDV plastic. etc). Look for scratches on the inner ring area of the bottom side of the DVD. those are an indication of foreign material on the spindle. It may be worse with disks that have been used many times. Just touching the hub area with your fingers can leave contaminates. Try first cleaning the disk hub area on the botton side. Stay away from the writable area. The drive spindle can be cleaned by removing the metal top from the unit and then removing the black plastic cover from the drive top (4 screws). Wipe clean the rubber surface on the top side of the spindle. Then replace the covers. As the unit ages, the rubber will get harder and more prone to slipping. A cotton cloth soaked in alcohol may be used to clean and refresh the rubber surface as a last resort. Reply to this message if you want pictures of the process.
Posted on Aug 01, 2008
SOURCE: DVD Recorder/VCR 80 GB HDD
Tyr using -r dvds ,,,,,that might resolve your problems
Posted on Oct 07, 2008
crayzeetrayn
  • 837 Answers
SOURCE: DVD recorder no longer acknowledges pre-recorded or blank DVDs
Have you tried a disc cleaner yet?
Posted on Jan 07, 2009
Demonic-2011
  • 508 Answers
SOURCE: I have a Panasonic DMR-ES35V DVD Recorder. The
You should use a specific DVD lens cleaner for your recorder, there are generic ones available I am sure. I do not recommend CD/DVD lens cleaners - far too abrasive, and there is a risk of damage to your unit if you use this type.
A generic DVD lens cleaner should do no harm and does not cost a lot. The type of cleaner I have used in the past is exactly like a DVD disc, with fine bristles, is a dry type, and it gently removes the grime and dirt film from the lens eye (you can probably obtain a wet and dry type that comes with a small bottle of fluid). These are the most reliable, and, unlike original CD lens cleaners, are far less abrasive. These lens cleaners usually work in DVD players and recorders, I've never had any issue after using this type.
Give that a try, see how you go.
Posted on Feb 02, 2011
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Hello, My Philips DVDR7300H has a recording error after burning to dvd - burns VERY Slowly, and then gets hung on 95% - then "Disk Error" and the disk is then unreadable. It reads other previously recorded...
This happens with a number of drives.
1. DVD Dye type - but as you have tried DVDs from a batch that works seems unlikely.
2. Some drives dont like +R or -R If using +R try -R etc. Also some drives have problems with RW's used previously
3. Drive head travel is faulty. Sometimes only recording a max of 4Gb or 90% on a disk works OK.
Good Luck
Jun 10, 2014 | Philips DVDR7310H DVD Recorder / HDD...
Dvd npt recording
This usually means that at best the DVD lens needs cleaning, so use a DVD cleaning disc and / or air duster to clean it or that there is a serious error with the DVD recorder itself an it will need replacing. Unfortunately this series of Tosh machines have had many issues with the DVD reliability.
Sep 11, 2009 | Panasonic DVD-RV41 DVD Player
Samsung DVD-VR320 DVD wont record and shows EC0509
Try cleaning the lens. A commercial lens cleaner should do the job, but if not, contact me again, and I'll try to help you clean it manually
Jan 04, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Unable to record,cannot read disk,is message on screen,
May be dust/dirt on the lens, so try blowing gently or using a DVD cleaner disk.
Oct 07, 2008 | Panasonic DMR-ES10 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD/VCR Emerson
Okay have had the same problem for 6 months, have bought 10 different brands and speeds of DVDs. Tried the reset idea, 5 times still no luck! I was so furstrated I was just going to buy me a new player.
Then I seen a laser lens cleaner, it was under $10 dollars at Wal mart. Came home reset the played 1st then tried the cleaning disc. I"M recording AGAIN and no error messages!
dukie 1558
Jan 22, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Disk error
clean the lens using coton and water
Aug 17, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
