Question about Toshiba 42HP66 42 in. LCD Television
Only half of the screen works
Turned off last night and it was fine, This moring turned on and the right side is black seperated by a line to the left side which is fine. Called where we bought the TV and said to unplug it and it would reset. Didn't work and I am getting pissed as the TV just went over a year old and has not been used much.
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
E machines flat computer screen began blinking and having colored lines going through it after turning black. By odd mishap I realized when I pressed on the screen it stopped doing that. That has been...
By the way, is it an LCD screen? I guess so. LCDs have small IC's either on the lower portion or in the left side of the screen. When these become loose, the tendency is to have vertical or horizontal lines on the screen. Hot air blower might solve the problem. But most will not. Better claim warranty or replace the unit.
Dec 07, 2009 | E-Machines eMachines Desktop PC
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Black Screen with vertical lines down the side?
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Toshiba 42HP66 42 in. LCD Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
