Question about Harman Kardon CDR30 2-Disc CD Recorder
Help with Harman Kardon cdr26
Is there any way to reset the CDR26 manually? (Like pressing the bottons on the front?) There is no signal coming through the RCA inputs in the back. I am just trying to save $$$ if it is something easy.
When we try to record to a CD, we get a message that there is no audio. If you plug the headphones in you can hear the audio so it is there. What is wrong?
Posted on Oct 12, 2008
  • 112 Answers
If you're sure you have the correct analogue source selected through the front panel and the record level turned up, it might be your unit is faulty. There is no reset sequence listed in the service manual of the sony model this unit is based on. And as the previous poster said, you need to be in record pause mode for it to do anything. You're not connecting a record player by any chance? These need to run through a pre-amp first.
Posted on Feb 29, 2008
  • 1,067 Answers
So u wann record u have to be in record mode 1st for signal to come throw and sorce vol up
Posted on Jan 27, 2008
Harman kardon avr 3600 no signal after firmware update..i think the firmware only got partial install
Try resetting the processor follow the link this will tell you how to do it.
Nov 06, 2016 | Harman Kardon Audio Players & Recorders
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
kardon service center for assistance.
to locate an authorized service center,
visit our web site at
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Harman kardon avr 151 stuck on tv speaker mode
Try this.
1. Press the front-panel Standby/On switch for more than three seconds to turn the AVR
off (the Power Indicator will turn amber).
2. Press and hold the front-panel Surround Modes button for at least 5 seconds until the
RESET message appears on the front-panel Message Display.
NOTE: After performing a processor reset, wait at least 1 minute before pressing any
Source Selector buttons.
Good Luck
Happy to help
Jan 04, 2014 | Harman Kardon Audio Players & Recorders
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I can't open the tray on the recorder side.
I had similar problem with both drawers. The belt from the drive motor to the drawer pulley is worn. has two belts 42-1050, 42-045 that are close enough in size to work. Remove cover, press down on tray, slide tray forward about half way and you will see the worn belt. Total cost of fix is about $12.
Dec 16, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Harmon Kardon CDR26 unit shuts off
This is a problem in the power supply, various components go dry jointed.
Dec 11, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
181 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
