Question about Apple iPod nano
Dock connector port
I have a ipod nano and one of the brass connectors in the dock connector port has either broken half off or been pushed inside, this means i can not get any sound out of my hifi when i put the ipod into its dock
It charges and works fine through the headphones
please help
    Sniper:
  • 55 Answers
Try going to repair your iPod at apple.
I don't think they will accept it because it is a old version.
You can try.
Hope this helps!
Nicholas
Posted on Jan 27, 2008
Charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
Aug 05, 2013 | Computers & Internet
Edifier brand docking station works with my ipod nano with auxillary cable but will not work in the docking port - no sound and no charging. Please suggest a solution. Many Thanks Stephen
There might be some issue with the docking ports. Try to connect a different iPod and see if its working, if its not working then there is some problem with the Dock connectors in the docking station.
Oct 10, 2010 | Audio Players & Recorders
The altec lansing inmotion does not charge my new ipod nano.What I can do
Maybe this could be the solution...
Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
Oct 30, 2009 | Altec Lansing inMotion® iM500 Docking...
Directions say it charges and syncs. When I
Look at:
Oct 09, 2009 | Altec Lansing inMotion® iM500 Docking...
Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Oct 04, 2009 | Bose SoundDock digital music system...
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
IPod Nano 3rd Generation
Hello Nada19,
The dock connector is the connector at the bottom of the iPod which the USB cable you use to connect the iPod to your computer plugs into. This is also the connector that is used to connect your iPod to a "dock" such as this one. An iPod dock, like this one is a device that you drop your iPod into for charging. It typically also has a connection for external speakers that can be used with the dock.
Not all models of iPod have a dock connector. And the actual layout of the dock connector varies from model to model. It sounds like you will need to use an iPod model that does have a dock connector to interface with the karaoke machine. You may also need an interface cable. Consult the documentation of your karaoke machine for more detailed info.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 01, 2008 | Audio Players & Recorders
How can I use iTunes to put photos on iPod nano?
"You can easily copy images from your computer to the iPod nano using photo sync in iTunes. Please note that you cannot import photos into iPod nano directly from a digital camera or media reader. If you connect an Apple iPod Camera Connector or Belkin Media Reader for iPod w/Dock Connector to iPod nano, you'll get a message on your iPod screen that says, ""The currently attached accessory is not supported by this iPod."" If you connect a Belkin Digital Camera Link for iPod w/ Dock Connector to iPod nano, you'll see a ""Do not disconnect"" message briefly, then the main iPod menu appears. For information on other iPod accessories that don't work with iPod nano, Some accessories that work with other iPod models won't work with iPod nano. Here are some items to note and the affected accessories: Photo Import iPod nano cannot import photos from an accessory (use iTunes to copy photos to iPod nano). It will not work with third-party card readers or with the Apple Camera Connector. If you connect such a device, you'll see an error message that displays for about a minute and reads, ?The currently attached accessory is not supported by this iPod.? Voice Recorders (Microphones) Like iPod mini, iPod nano does not work with third-party voice recorders. Apple iPod Remote Because iPod nano does not have a remote port, it won't work with any accessory that requires it, such as Apple iPod Remote. Headphones Port Location The headphones port on iPod nano is located on the bottom, therefore, it won't work with any third-party accessory that requires that this port be located on the top. No Video Out iPod nano does not support video out through the dock connector or the headphone port. iPod nano is not compatible with the Apple iPod AV Cable designed for iPod with color display (and iPod photo). If you need to use any of the above devices, you'll need to use an iPod model that supports the accessory. "
Sep 28, 2005 | Apple iPod nano
Apple iPod nano Logo
213 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
