Question about HP Officejet Pro L7680 All-In-One Printer
HP L7680 All in one will not send faxes from PC S/W interface
I have 3 networked PCs, 2 of which can use all the 7680's features from the S/W interface. One PC can do everything but send a fax through the "Solution Center." Printing works, scanning works, the network is fine, the fax setup test passes fine, everything looks good. When scanning a page to fax, the scan works and then it simply says: "The fax could not be sent. The fax will be moved to the fax log where you can resend it."
I was on with HP tech support for 2 hours 40 min., and we ended up reinstalling the entire 7680 software suite. Everything installed fine; still no dice trying to send a fax through the S/W interface. Faxes work fine diretly from the device, and from the other PCs. This is bizarre - any help would be appreciated.
Eric
  • 4 more comments
  • ejc150 Jan 27, 2008
    Further information or symptoms:
    When using the Solution Center, neither fax preview or the fax log work. When I click on "Recent Faxes," the Last Name box drops down, and it looks like there is simply a comma in it.
    I just installed the latest updates from the auto-update dialogue for the HP software. I have .netframework 3.0 installed, flash, shockwave, java look ok.
    I just tried looking at my norton firewall rules, comparing them to working PCs. Did not see anything amiss for program controls, but made the "allow" anyway. No change-still non-functional.
    The installation process asks if you want to look for latest updates, which I did at the time.
    Why then do my other 2 networked PCs work just fine to the 7680, having been installed with the exact same process? Faxes work fine, the fax logs work, etc. I suspect something else.
    I'll be away for awhile - won't be able to pursue more probably till tomorrow. Thanks for the input.
  • windsurferVP Apr 29, 2008
    I have an hp L7650. At one time, this machine did fax from the solution center, but it doesn't now. The machine does scan the document, but does nothing later, only displaying on the computer monitor: "The fax could not be sent", and asking that the user refer to the log to send at a later time.
    As with the other users, now the fax log is not available from the Solution Center (if you click on the menu item, the disk is obviously cranking, but nothing happens). The fax log was once present.
    I only use the fax occasionally for urgent authorizations to my financial advisor, so a number of things I know of have happened including XP updates, new firewalls (which aren't showing any alarms or blocked programs).
    The fax self test shows that the unit does work, and when the test runs, I can hear the dial tone. However, when I try to fax from the solution center, I don't hear the dial tone. I suspect, but don't know, that the fax operation never got so far as trying to dial.
    Have not tried to reinstall, based on comments from previous that that doesn't work.
    Scanning and printing functions seem to work fine.
After much thrashing, here is the solution to the problem. Somehow the printer drivers lost coordination with the corresponding Windows supporting programs. You would think that reinstalling the printer drivers would fix the problem, AND IT DOES, but there are 3 tricks:
· Uninstall everything associated with this printer with the install disk in the computer (this may really not be necessary, but it worked for me). [This is also the solution when the a window comes up asking for TrayApp to be inserted using a disk—they mean the hp install disk].
· After the un-install, MAKE SURE you ALSO delete the printer using the control panel. This is critical. If this doesn’t happen, the corresponding Windows software is somehow hooked to the wrong thing when the reinstall happens. Then reboot the system.
· Install the new drivers with the printer off, and the USB disconnected from the printer. Reboot the system [not sure the reboot is necessary]. After the computer has booted, connect the USB, and power up the printer. The computer will recognize the printer and put the printer icon in the Control Panel.
It turns out that correcting the driver mis-coordination by BOTH uninstalling the printer drivers and taking the printer out of the control panel, then properly reinstalling solves BOTH the fax problem, and the protection fault problem! Amazing such a little thing can make such a difference!
Posted on May 02, 2008
    Genius:
  • 1,067 Answers
Did u try to download ther latest software all idrect form site dont use cd
Posted on Jan 27, 2008
  • 2 more comments
  • nick helpap
    nick helpap Jan 27, 2008
    do u have netframework 2.0 installed from microsoft and latest flash and shockwave and java ok
  • nick helpap
    dont wann do that u wann dl latest simple driver from website not use cd at alll ok
  • nick helpap
    cuse sumting in this system doesnt like it maby spywar cookies temps clean all yur junk out with cc cleaner happends sumtimes try this wont hurt remove all old printer software from add remove then run ccleaner.com tool gets rest junk out left over ok so we can install fresh copy download latest drivers from website for yours only ok not do not use cd just do this 1st see what happends dl all latest software they offer
  • nick helpap
    ok let me know cuse this what u will have to do ok also tell the what printer port its using com 1 2 usb ect in printer menu
HOW TO USE THE SCANNER FEATURE ON THE HP PCS 950
You can start a scan from your computer or from your HP PSC. 1 Load your original.
2 Press Scanner, then press PC Save, if not already lit. This saves the scan to your computer.
3 Press Black or Color. For Windows, a scan of the original appears in the HP Image Viewer. For Macintosh, a scan of the original appears in the HP Workplace. In the HP Image Viewer, you can edit the scanned image. When you are done viewing the image, click Accept.
The HP PSC does a final scan of the original and sends the image to the HP Photo View Center in Windows. In the HP Photo View Center, you can:
- edit images, including adding text
- creative printing
- create and print photo albums
- send to fax, e-mail, web page, or other programs.
additional information can be found on this website:
http://www.retrevo.com/support/HP-950-Multifunction-Printers-manual/id/260dj582/t/2/
Sep 14, 2010 | Office Equipment & Supplies
HP officejet pro 7700 series
Tried to set up wireless feature now I can't make copies or send a fax manually???
Feb 10, 2010 | HP Officejet Pro L7680 All-In-One Printer
Cannot renew IP address on some PCs, each day it's a different PC in my house. This started happening a couple weeks ago.
It is a router's default behavior to lock some IPs to a particular PC which are usually using it on the network. It is a leasing feature. Example, if your PC is using 192.168.0.125, and your IP range in your router is 192.168.0.100 - 255, every time you connect, though you are alone in the network and no other PCs are connected, still your router will lease 192.168.0.125 to you unless otherwise you disable this leasing feature in your router's admin interface. Renewing IP from the computer side do not alter the router's leasing policy. So right clicking on the network icon and selecting Renew IP won't help. What you need to alter is your router's IP leasing behavior.
Feb 01, 2010 | Dell Wireless 2350 Router
HP L7680 All-in-One will not scan or fax
connect the phone line in printer and set the parameter like auto answer and sending and receving mode also install the scanner driver .just reinstall the printer driver it will installl the missing components.
Dec 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
Is hp 1040 fax compatable with pcs
No it is not. You need an interface connector in order to uswe it with a computer.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
My officejet pro L7680 does not receive fax. The ring setting is for 3 rings and the little green light is on the auto answer switch. It sends nicely.
Since you can send faxes, it's not the phone line or cord. It's most likely that you have the "distinctive ring" option set to something other than "all rings", check that first.
Apr 23, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing
Try clearing your print spool file
Oct 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax feature in HP PCS 950
Try switching the dialing mode to "Pulse" and lowering the baud rate for the printer.
May 02, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
613 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
