Question about Video Cameras
Lines on video
My family does a bit of water skiing and when recording on my JVC Everio GZ-MG50AA recorder, playback has fine vertical lines which are very distracting and make the picture blurry. Whenever the suject moves or the camera moves, even slowly, this happens. (VERY slow moving or still objects come out quite clearly but it's really annoying trying to watch any action!) I have tried all the settings I can think of without any success. At the moment I'm getting much better quality video with my fuji digital camera than the camcorder, which sort of defeats the purpose of having it! Any tips please?
I've found out that if the little internal battery that holds the date and time is run down, then the camera can't focus on moving things well. I left mine plugged in all weekend, now can record action. Some can be replaced - like a big watch battery.
Posted on Oct 20, 2008
My JVC GZ-MG21EK won't turn on, record, or playback unless it's plugged into the mains. It works perfectly when it's plugged in but won't function otherwise, no matter how long I leave it to charge.
Rechargeable batteries don't last forever. When I searched Amazon for "JVC GZ-MG21EK battery", I found lots, from about 9 pounds sterling ($12).
Nov 21, 2010 | JVC Everio GZ-MG21 Camcorder
Vertical lines on video
best bet to get that video on pc 1st ok then convert it to dvd format 720x480 29.97 fps mpeg 2 use allok software online to convert then burn to dvd play perfect use nero 7 to make dvds proably is flat screen your resoution proably dont match up or the verticaly sync in hertz is higher cuses the vertical lines so do that way to make pro videos
Jan 27, 2008 | Video Cameras
Everio software
my JVC Everio GZ-MG330 keeps saying "recording failure" when i press record. how do i fix this?
May 08, 2010 | JVC GZ-MG330 HDD Camcorder
JVC G-z-mg365bu video management file is broken to record/playback video. recovery is required recovery
For broken files, everio will prompt you to recover once switched on. If you mean deleted by accident, you can use file recovery software like Final Data Enterprise and a lot more. Mostly can be recovered, sometimes 80% or 90% of your total recording. Good Luck
Feb 25, 2010 | JVC Everio GZ-MG365 HDD Camcorder
No sound during Playback
we have the same problem..mine is sony dcr-sr200
Feb 05, 2010 | JVC Everio GZ-MG37 Camcorder
My JVC Everio GZ-MG135aa fell off of it's tripod stand and now the lcd is white on the right half and has bright lines on the other half (this is all it will show) If I hit record it still records and...
LCD panel needs replacing - this is the classic case of detached screen ribbon, which unfortunately is not repairable without silicon printing equipment which costs thousands. Also check playback on another device (ie streamed through your PC) to make sure the heads haven't become misaligned.
Jul 17, 2009 | JVC Everio GZ-MG155 Camcorder
Manual for JVC GZ-HD7U
i recorded my video clip vertically! i need to rotate them from the camcorder! how do i do it????
Nov 24, 2008 | JVC Everio GZ-HD7 Camcorder
Playback on PC has no sound
Are you playing the video back through the camcorders utility ? Sometimes by clicking on the file through windows explorer you will get the picture but no sound, this happens for the Sony camcorder but is fixed by running the playback through the motion picture browser application supplied with the camcorder.
Oct 24, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Help me
Hi .Just click on Menu-button, then with joy-stick (on left side of cam-monitor)go up tu "Rec Media for Video"...then you push joy-stik to the right...and then you see 2 lines media types -HDD and SD....again with joy-stick you push to up side (where is HDD )...and then again push joy-stick to center( to select the recording media type)...and your cam is ready to rec on HDD
Jul 09, 2008 | JVC Everio GZ-MG130 Camcorder
Unable to view or record video
i fear you have a bad CCD. replacement of the same may rectify the problem.
Oct 08, 2006 | JVC GR-D33US Mini DV Digital Camcorder
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
Video Cameras Logo
203 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
