Question about Kodak EasyShare V603 Digital Camera
Camera Won't Turn On; the 3 lights are Fashing Red
Have tried two batteries and different chargers - still 3 flashing red lights. Emailed Kodak Tech Support. Their response:
"Kindly take out the battery and memory card, and then connect the camera directly to the AC adapter. Next, switch the camera ON. If the camera turns on fine (without the battery and card), then we might be dealing with potential battery problems. On that note, you may use a different charger to make sure that battery is fully recharged.
If the camera will not respond, then we need to send in the camera for an evaluation and repair."
Before I send it anywhere, does anyone else have an answer?
Thank you.
Matt
    Problem Solver:
  • 6 Answers
Sorry, didn't see the part about 2 batteries and chargers. I've had the V603, it broke, and I took it apart. It is a very complex little camera and I don't recommend opening it up past taking off the front cover and rear cover.
The CCD is just behind the lens assembly, and the motherboard is behind the aluminum cover for the slot for the SD card. Most components on the motherboard are surface mounted and trouble shooting or soldering is tough! You might try cleaning the battery contacts using a pencil eraser (just go through the battery compartment opening). Even with new batteries, if the battery contacts on the camera have any corrosion, the camera won't be getting full voltage.
If you take the front or rear covers off, you might see if you can see any loose connections by doing that. Other than that, probably a lost cause. Sell your camera on E-bay as one that needs repairs. There are many people who would buy it to use the LCD from it to repair their 603V. If you like this model, I'd look for a cheap replacement on e-bay.
Posted on Jun 28, 2008
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
I have 3 blinking red lights
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 10, 2010 | Kodak EasyShare One Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare C643 Digital Camera won't take picture
take your battery out for 5 mts then try it again
"Was this helpful?"
Apr 02, 2009 | Kodak EasyShare C643 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Camera won't turn on
What sort of batteries are you using ? Alkaline do not have the oomph to run a camera They need to be Ni-Cad or Ni-Mah Check out the Tech Support Web Site at Kodak
Jul 05, 2007 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare V603 Digital Camera Logo
93 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
