Yahoo messenger installing
I could not install yahoo messenger.it automatically closes when its running nearly to 4% each and every time.so i vexed by tried again and again.whats the problem actually.then no one downloads getting fully downloaded.it couldnt be...
Actually maybe you installa yahoo messenger is not fix.to your download. or maybe the software you down load are have many virus so if your install they are not complete install..
Posted on Jan 27, 2008
I woul like to run yahoo mesenger at start up wiht out having to ok it evry time i restat my pc. in vista i had no problem but, wiht win 7 i canot figure it out
When you install Yahoo! Messenger on your computer, the program is adds itself to your computer's startup list. Each time you boot your computer, Yahoo! Messenger, and all other programs included in the list, starts automatically. Having too many programs on the list might reduce your computer's performance. To prevent Yahoo! Messenger from loading and popping up on your screen each time you boot your computer, you must remove it from the startup list. Yahoo! Messenger allows you to disable automatic startup through the program's preferences menu.
1.Open Yahoo! Messenger and log in your account.
2.Click the "Messenger" button at the top of the Yahoo! Messenger.
3.Click "Preferences" and the "Yahoo! Messenger Preferences" dialog box appears on your screen.
4.Click "General" and remove the checkmark from the box labeled "Automatically Start Yahoo! Messenger."
5.Click "Apply" and click "OK" to close the dialog box.
I hope you find it very helpful. Thanks.
Sep 06, 2011 | Yahoo Messenger
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Yahoo messenger send automatic message to friend list
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 24, 2011 | Yahoo Messenger
Window 7 home premium os and yahoo messenger dosen't intialize...installed 4 to 5 time
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5. Click the "End Task" button.This will temporarily close all background applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 19, 2011 | Yahoo Messenger
Cannot re-install Yahoo Messenger as every time I re-boot, an error message says that it cannot find clientmanager.dll file
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Feb 09, 2011 | Yahoo Messenger
My yahoo messenger on I phone 4 not working when I click on yahoo messenger a black screen comes what's wrong
Hey naeema426,
This is a known issue with Yahoo Instant Messenger and the iPhone 4. The most common solution is to remove the application and re-install it again. Sometimes when Yahoo installs it doesn't have the correct permissions to place the files where they need to go.
Here is a quick video to show you how to uninstall an application on the iPhone4
After you have successful removal of YIM re-download the app using iTunes or follow this official link from Yahoo.
Also make sure you have the latest version of YIM for Iphone 4. The newest version offers great new features like voice chat and video conferencing! Super cool! Here is a great website that will explain all of the cool new features of YIM for iPhone 4.
A Pleasure,
Vex
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 12, 2011 | Yahoo Messenger
Dear Sir I installed yahoo messenger 11, but at last moment of installation i am getting the yahoomessenger.exe-application error"the application failed to initialize...
Jan 03, 2011 | Yahoo Messenger
Always hang up every time i sign in to my yahoo messenger.
uninstall messenger and then Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reg in out also reboot your system. All other background applications will return to their original configurations.
Oct 04, 2010 | Yahoo Messenger
I wat to sign in to yahoomessenger
Dear Brother,
  • Install messenger by Clicking HERE
  • Simple Setup File will Download
  • Click on it and Run without Disconnecting internet Connection
  • Downloading may take Several time Depends on Your Connection Speed.
  • After Downloading Completed Click Next Follow instruction Finish Installation
  • Yahoo messenger Icon will be automatically place on Desktop after installation
  • Click on it(if there is not loaded Messenger Automatically after Installation)
  • Type User Name Correctly(your Yahoo ID)
  • Type Password Correctly;check& make sure to OFF CAPS LOCK ON (Your Yahoo Password)
  • Click on Sign in
  • You are Signed in
If you want to add Contacts in Messenger
  • There you can see a PLUS(+)button as Top left of yahoo messenger(if you place mouse button near to it,then there will be appear as 'Add a contact')
  • Click on it
  • Type the Messenger ID you want to add correctly(Yahoo ID of your Friend/Relative)
  • Click on next
  • Yahoo will check and make pending for accepting your Request
  • After Receiving your Request(When your Buddy Come online and accept Your Request) ,Then Both of you are able to See Each other if ONLINE
  • This way you can Add more Buddies to your Messenger.
  • You are Ready to Use..
I like To Know your Feedback Do Rate Me..If this Helped you..
Hope This Helped YOu..
Thanks For Using FixYa
Apr 08, 2010 | Yahoo Messenger
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
