Question about Yamaha HTR-5660 Receiver
YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
I have bose main speakers and cirvin vega surround, when I am watching a movie with the audio set to dvd auto I will get a loud poping sound out of my mains. example when their is a loud explosion or gunfire on the tv with a bright explosion or light It will pop? Any Ideas?? I do not want to pop my speakers and I have been gentle with them so far.
  • 1 more comment
  • cobfire Jan 27, 2008
    I have monster optical and monster hdmi cables. I have the hdmi going to the tv and the optical to the receiver.
  • cobfire Jan 29, 2008
    I will try this I thank you for your time
  • Alan1962 May 11, 2010
    How do you have the amp connected to the DVD player? I believe this amp has both analog and digital audio inputs, and I would guess you're using the analog (a red and a white RCA cable). Try the digital (optical) from DVD to amp and see if the problem still occurs
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Posted on Jan 29, 2008
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
Jun 25, 2011 | Yamaha HTR-5660 Receiver
Well i have a yamaha natural sound av receiver htr-5660 and ive connected 200 watt speakers and my problem is my tweeters are only working and i would to like know step by step to on how to get the...
"200 watt speaker" is meaningless. What brand and model? Be advised that stripping parts from an all-in-one audio package for redeployment with 'standard' audio components doesn't guarantee compatibility or safe function.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5660-Receivers-manual/id/394ci074/t/2/
The amp has selectable impedance. See page 16.
Mar 15, 2011 | Yamaha HTR-5660 Receiver
Tanaka htr 5660 was working fine. Not sure what button I hit, but sub and rear surround quit working. I have followed troubleshooting guides and to no avail. Connections are all fine as well
You must have hit the DIRECT button . In this mode it produces pure stereo sound by shutting down the multichannel Digital Sound Processor (DSP). Only your front Left & Right speakers will work
Mar 10, 2011 | Yamaha HTR-5660 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Yamaha HTR-5660 receiver but no surround sound
have you tried putting it in a different program mode?
Jul 04, 2009 | Jensen CS10 Speaker
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
Rx-v563 backround music much louder than people when watching tv
I would check your center speaker wiring and setting. Then switch to a different audio setting (pro logic, theater...)
Jan 12, 2009 | Yamaha RX-V563 Receiver
Surround sound problems
Try changing your cables
Mar 11, 2007 | Yamaha HTR-5660 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
Yamaha HTR-5660 Receiver Logo
193 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
