Question about GE Profile Harmony DPGT750EC Electric Dryer
Ge profile harmony dryer
My dryer will run a little while and dry clothes, but after about 2 to 5 minutes it makes a noisy like a piece of rubber rubbing in it and then sometime it sound like water run into it. then it stop heater and will not dry the clothes at all.. if you open the door there is moister in the dry all most like a mess. in the dryer.. I also have had a repair man out to the house and he said there was not anything wrong with it.. but it is doing it again.. he don't know what to look for next.. I don't won't to have to buy thing just to see if that will work.. I can go buy something new for that.. can you help.. Thanks ddc
  • 770 Answers
You most likely have a clogged venting system going to the oustside.. Try this pull the dryer away from the wall remove the flex venting pipe.
Run a load now yes i know the heat and moisture will come in the house but it is just one load(open a window) if it works ok then you will need to get someone out to clean your vent and your money back from the repairman who came out .....any technician worth anything should have told you this.....98% of long dry time calls are a plugged venting..just and FYI...Hope this fix ya if so plz rate
Posted on Jan 27, 2008
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dampness
If the clothes are damp, First check and make sure the dryer is level this is very important. If it is the you can touch the dryness level on the screen and move it to more dry.
Apr 20, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
89 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
