When I put it in, my screen/computer freezes - my mouse and key pad won't work - the directions say it will install automatically. The computer recognizes the new hardware and then freezes - help
Comments:
Jan 27, 2008
- I am at an open house now and don't have the card with me - but I will definitely try what you have described when I get home. I will let you know how it turns out and thank you very much.
This seems to be a basic hardware conflict; shut down and UNPLUG the system, then MOVE the 1394 card to a different slot on the motherboard, then reattach the AC power cord, reboot the system, and see if the problem has been solved.
If it is a Gigabyte motherboard (and some other older types) Try this:
1. (shut down) remove the card.
2. (restart) install the card FIRST.. in other words, manually install it and specify the card (any 1394 will do, the driver will be updated later)
3. Then sut down, install the card again, and restart. If you get past the MSG this time, then go to system CP/hardware and update the driver if it is not working smoothly now. Otherwise, if it is XP or Vista, and it runs your firewire device OK, don't unfix it! :)
Installed the Sabrent USB-UF6 USB/Firewire PCI controller into my P-4 1.3Ghz XP SP-2 machine. Tried...
(More)
Installed the Sabrent USB-UF6 USB/Firewire PCI controller into my P-4 1.3Ghz XP SP-2 machine. Tried to load up the drivers from the enclosed cd and got the USB drivers to load but the IEEE part of the board is still showing a problem on my Device Manager and says that it could not load the drivers or that they were corrupt. However, it shows drivers there though I do not know if they were Windows drivers or the drivers from the box. also, the wizard on the CD asked for a serial number before it would load the Ulead video capture program included on the software but there is no serial number anywhere. This is retail. Is there a site to download the software and drivers? The tech at the online store suggested moving PCI slots.
TV to Go A03 Genius message: "Failure to Initialize" running under vista and windows 7....
(More)
TV to Go A03 Genius message: "Failure to Initialize" running under vista and windows 7. Dont know what to do... Does any body can help me??
I have it connected to VCR and tv but logo does not appear for converter as instruction indicates...
(More)
I have it connected to VCR and tv but logo does not appear for converter as instruction indicates nor does it appear to record
My HP2133 will not recognize the HP Express Card after having downloaded the drivers for the device....
(More)
My HP2133 will not recognize the HP Express Card after having downloaded the drivers for the device. My goal is to take cassette tapes that i created 30 years ago (kids singing in the back seat of the car) and input the amplified signal into the bananna jackes that are provided with the Express card. Form there I wish to create a wve file that can later be burned onto a DVD for permanent keepsake storage.
The Express card never lights up.
