Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Toner Cartridge IR3300
How do I change it?
  • Anonymous Mar 26, 2008
    I have added toner, but the copier is still saying that I am out of toner. I have already powered off and back on. Any suggestions?
You dont actually 'change it' you just refill it.
You're gonna have to pull out the toner cartige og place the new toner onto the old one. Pad the toner gently on its back, to empty it into your 'old toner'. afterwards you remove the new toner cartige and push the old one into place again.
Posted on Mar 13, 2008
  • 37 Answers
Hi, when you purchase a new toner , the directions to replace is on package , try following that....
Posted on Feb 05, 2008
2 Suggested Answers
6ya staff
SOURCE:
pineworks
Clive
  • 4345 Answers
SOURCE: HOW DO YOU CHANGE THE TONER CARTRIDGE IR3300
Hi
I have put PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/User-Guide-Canon-ir105 -2200 -2200i -2800 -3300 -5000-5020-6000-6000i-6020-7200-85-8500.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
HL215ON changing toner How do I change the toner?
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
Jun 01, 2011 | Brother HL 1240 Printer
I change my toner, and i have msg. "ORDER
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 13, 2011 | HP LaserJet P3005 Printer
How do i change the toner on this copy machine?
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
Sep 24, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Hi
Feb 03, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
What does the display read when toner is out, or toner cartridge is out
If this message appears and you can not make any copy, replace the toner
Original Toner CANON C-EXV3 Black Canon iR2200, iR2800, iR3300, iR3320i.
Oct 30, 2009 | Canon imageRUNNER 2200
We have been sent a toner cartridge for our ir3300 but despite directions on the side of the box it does not appear to fit
Canon toner type GPR-6, correct? Open the front cover. Rotate lever to release toner/developer unit. Pull the unit straight out until it stops. Insert new cartridge to line up with top of toner/developer unit at a slight angle (lower at back) Once the cartridge stops at the rear (I would hold the toner/developer unit with one hand while inserting the cartridge) then lower the front end of toner cartridge down on top of the unit.....press down until toner cart. clicks into place. You will know because a tab pops out the front with clear plastic attatched. Pull the tab to release toner and release top of toner/dev. unit. Keep pulling until it stops. Wait about 7 seconds, now tap on toner cartridge to release all loose toner (don't forget to shake toner before opening) After about 15 seconds, toner should be fully loaded. Now push top cover of toner/developer unit back in until it latches, you will know because the empty cartridge releases from the unit. Now remove empty cartridge, reinsert unit, turn latch handle and close front cover.
Oct 07, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
386 people viewed this question
Clive
Clive
old marine
old marine
Ekse
