Question about Car Audio & Video
Car radio harness diagram
I want to fit a double din cd player from a 2006 ford bantam into my new car,the seller could not supply the plugs that fit into the back of said radio...And i have no idea which are speaker wires,power supply or negative.
Ive browsed for hours and cannot find a solution-pls help
  • MSPASSION Mar 12, 2008
    I CANT FIND WERE TO FIND THE HARNESS TO MY STEREO EITHER. I DRIVE A 91' CADILLAC DEVILLE AND I CANT FIND IT ANY WHERE.
I don't know where to find the power wire for my cd player can yall help me i drive a 97 gms serria
Posted on Jun 24, 2008
6ya staff
SOURCE:
Hi i have a 2006 bantam 1300.how easy is it to fit new rubber stablizer bushes.thanks don
It is not Hard at all, they are Slitted and you can remove and replace fairly easy
Apr 10, 2013 | 2005 Ford Bantam 1.3i
How to integrate the pioneer deh-1300mp into a 96 Dodge 2500 Centurion diesel truck to replace a radio/cassette player.
The simplest way to swap the stock radio out for the cassette player would be to go to a radioshack or bestbuy, normally they will carry a double-din to single-din adapter so that the smaller after market radio fits into the existing location snugly. They usually also carry a wiring harness adapter that will plug right into your dodges existing harness and you can just wire nut or solder & shrink wrap the adapter to the pioneers harness, saves a lot of time and insures everything is where it needs to be.
Normally you can get both adapters for under $15, hope this is helps.
Mar 08, 2011 | Pioneer DEH-1300 CD Player
Does this unit fit into a 2007 montana van
This unit will fit into your van. There will be extra space in the dash after you install it. The standard measurement technique for head units is DIN. A single-DIN unit is the normal size of a head unit. Your stock unit is a double-DIN unit. The Clarion NZ500 is a single-DIN. It will fit, with space to spare.
Mar 08, 2011 | Clarion NZ500 Car Video Player
I don't found wire harness, for chevy 2006 equinox, double Din car stereo Radio(Delhi Delco) diagram.
http://wiki.answers.com/Q/What_is_the_stereo_wiring_diagram_for_2006_Chevy_trailblazer
Feb 27, 2011 | Car Audio & Video
Will the Boss BV9555 fit a 2004 F150 ( new body style) super cab with factory stereo .
the radio is double din but the opening is only din and 1/2. it would fit but requires some customising
Feb 06, 2010 | Boss BV9555 Car Video Player
How do i change a am radio and put a am/fm in.a 1993 chevy pick up
This is the best way to do it. First, buy a radio. I doesn't matter what kind, you can have tape deck, or cd. Anything you can get at a place that sells car radio's that is a single din sized.
Then get the in dash adapter kit. this will make the radio fit in the space. If you have a double din space, which is twice the size of most after marked head units your gonna need this, and that what you most likely have. If you do you could actually get a double din size radio if you wanted but they are usually $$.
Next get a " 1993 chevy to (what ever brand radio you have) adapter". So if you get a sony head uning, then get a "1993 chevy to sony adapter"
Note some times they come in to peices, "car to universal, then universal to radio type."
Best buy sells these, and other places that sell car audio head units etc.
you never want to cut the stock wiring harness plug off. You just make wiring the radio a pain, and if you ever want to change it down the road, its another pain.
Use the adapter to connect the radio easily. Remove the radio, usually there are screws under a cover part of the dash. this peice usually come off by pulling it, and usually has no screws, but chey some times has a couple.
then there should be 2 screws on each side to remove the unit.
Install the din adapter to fit the new radio, then plug in the wire with the adapter.
before you replace all screws and covers, test the radio to make sure it works because if you don't and you forgot a plug you will have do undo everything again.
if everything seems good replace screws and covers.
Oct 10, 2009 | Car Audio & Video
Double din radio doesn't fit in dash
i have a 2002 ford escape and i bought a double din radio and it did not fit and found out it is actually a din and 3/4 with out serious mods (cutting a bigger hole in dash) double din wont fit i bought a single din stereo and a din a 3/4 dash kit works fine
Jun 10, 2009 | 2003 Ford Escape
Car Audio & Video Logo
302 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
