Question about Kogi l4ax 14.1" Flat Panel LCD Monitor
Grey screen When I boot up machine Mac G4 quicksilver the Kogi screen is just grey. I am am also running a 24" Dell off the DVI port of the G4. The kogi is running off the Matrox RT mac board inside an expansion slot in the G4. I can't even get th OSD controls on the monitor to show?
  • tvshooter77 Jan 27, 2008
    I have tried two other machines that I know are working with working video cards and the same result on the KOGI - just a grey screen, no menus or icons - can't even bring the internal OSD?
    I have also connected the cable that was connected to the suspect KOGI and it works fine with another monitor :-( Just a grey screen when connected to the KOGI.
    Problem Solver:
  • 18 Answers
First, you need to eliminate the video card or the Kogi as the problem, which is quite easy to do by testing a known working monitor on the Matrox card.
Posted on Jan 27, 2008
6ya staff
SOURCE:
The text and pictures on my Kogi monitor are too big for the screen. How do I fit everything on the screen to the right size?
Sounds like your monitor isn't set up at the correct resolution.
If you're running Windows, go to your Control Panel and into Display > Screen Resolution.
Try setting it to 1024x768 or higher.
Mar 07, 2011 | Kogi L7CH Monitor
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I have a powermac G4. When I turn it on it chimes but there is no display and a red light on the motherboard. Checked the power supply - all voltages are good. Bad motherboard or video card?
There is one red LED on the Power Mac G4 QuickSilver logic board. It indicates that there is power to the board and does not imply a fault condition.
Do you hear mechanical activity from the drive? It is possible the machine is running fine except for the display or graphics card. Try another display. If you have another Mac, you can also try starting the machine in target disk mode by holding down the T key at boot (your machine was built in 2001, so it should have this feature) and see if you can access the internal drive from another machine. This should eliminate the motherboard as the culprit.
May 16, 2010 | Apple Power Mac G4 Desktop
I just hoolked up a Kogi l7 eh 17
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Apr 12, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor will not resolve screen
Startt the pc in SAFE MODE  and change thr resolution of the screen, the computer does not work on 1280 X1024, so AT THE BOOT TIME  PRES F8 chose save mode with windows, tan on the property of the display change the video resolution at 1280 X1024, and i think you don't have the video driver instaled not sure but u can chek that as well.chek run WINDOWS UPDATE if your diver is not in place. to chek driver take a look in computer management  DEVICE MANAGER.
Jan 20, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My Kogi 17 inch monitor illuminates for 2 seconds and then the light goes out. The monitor is still on but hard to see. Each time you power cycle the monitor, the display appears normal for exactly 2...
Hi and welcome to FixYa,
Initially, lets try determining which is at fault.
  • power supply (unlikely) - the unit powers up, even after the display going off, the monitor is till on;
  • LCD screen (possibly) - will have to be determined later;
  • CCF Lamps (backlights) and/or inverter (most likely) - a check; power on the unit, run through the routine, change channels etc. with a flashlight shine obliquely against the screen. If with the use of the flashlight a darker semblance of the desktop could be seen, then you have just confirmed that it is either the CCFL or the inverter and definitely not the LCD screen.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 08, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor ... it goes blank
Where can I buy the power cord for my KOGI L5QX?
Feb 09, 2008 | Kogi L7CH Monitor
Kogi l4ax 14.1" Flat Panel LCD Monitor Logo
143 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Ekse
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
