Question about Kicker ZX650.4 Multi-Channel Amp - 480W ZX Series 4-Channel 650W Bridged Remote KickBass Car Audio Amplifier
Amp Power LED Display blinks red and no sound
I have the Kicker ZX650.4 amp. When I installed it, it worked fine, but when i hit a sharp turn the other night it stopped working. The power LED on the front now blinks red very interminantly. The ground is good and the amp is getting power, and the remote is connected because it only blinks when the stereo is on. The RCA inputs are also getting voltage according to my multimeter. The fuses on the amp are good. Anyone have any idea what is going on? The manual for the amp does not even have a blinking red light listed as a potential problem in the troubleshoot section.
  • gustavo7 Mar 02, 2008
    mine stopped working on my way home. it was during a turn but i dont think it actually had to do with the turn.
  • FecalMyst Nov 21, 2008
    Wow, I have the same identical problem. I had this Kicker amp installed in another car and right before I sold the car, the sound from my front left speaker started to cut out on turns periodically (left to be specific). I removed the amp when I sold the car and reinstalled it in a new one with all new wiring, speakers and head unit. About 2 months later the amp started to cut out on the front left channel again when making turns just like it did in the other car. I found that after this happens, if I turned the volume up to about -20, the sound would come back in that speaker and then I could turn it down again to a normal listening level. Now the red light stays flashing when the stereo is turned on and emits a weird short swoop sound every 3 seconds from the front left mid driver. I am going to take it apart this weekend and see if there is any thing obviously wrong internally with the speaker inputs.
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Posted on Jan 28, 2008
    New Friend:
Hi Perry, my amp is doing the same thing and I tried your suggestions and the meter does fluctuate between 12v and in the upper 11v whenever the lights switch between the Power Light and the Protection Light. I unhooked all of the speaker inputs and the RCA cables and it still did the same thing. Should I try and see if another ground will work?
Posted on Feb 23, 2015
SHARP LED TV does not power on
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 10, 2016 | Sharp Televison & Video
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
KICKER AMP
sounds like a bad ground or power.
Jul 12, 2008 | Car Audio & Video
My kicker zx 750.1 amp is not working.
that is protection built into the amp. try turning down the gain levels on the amp
Apr 20, 2008 | Car Audio & Video
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Car Audio & Video Logo
961 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
