Question about JVC HX-D7 Shelf System
Protect mode power turns off after protect flashes 3 times
  • 3 more comments
  • judru Feb 08, 2008
    turnoff by itself after being turn on within five seconds.
  • Anonymous Jan 27, 2009
    set goes to protect after 5 seconds
  • Anonymous Apr 13, 2009
    aparece a menssagem protect e depois desliga.... alguma solução pra isso?
  • Anonymous Apr 21, 2009
    i turn on my stereo and then that protected mode comes on and i wish i could fix it i have some cds i wanna take out
  • dj_xclusive Apr 22, 2009
    The Protect Mode Blinks Three
    Times And I'm Mad Because I Want To
    MTX Speackers To Them :(
  • 38 Answers
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Posted on Mar 04, 2008
When i turn on my Stereo, "PROTECT" flashes and then shuts down automatically.. Is there a wayy to fix this or no.?
Posted on Aug 13, 2009
Take out the antenna for fm/am and it should work :) disconnect speakers as well and make sure wires are fit properly in there spot. Maybe switch the Left speakers to the right input and vice versa. I did all this and it works again. yaya
Posted on Apr 14, 2012
2 Suggested Answers
jango2
  • 38 Answers
SOURCE: protect mode
Hi ,
Jango
Bravia flash 3 times
[Over Voltage Protection 03]. Check its main power supply regulator board for the fault. For more information go to http://electronicshelponline.blogspot.com/
Dec 10, 2013 | Televison & Video
Panasonic viera problems
The internal power supply is failing
Jun 15, 2013 | Televison & Video
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
I replaced the main board in my sony Kdl-32S300. When turn on power, the back light flashes 3 times then goes into standby mode after which the standby light flashes 12 times in sequence. What could be...
B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Have you set the output voltage correctly?
Mar 24, 2011 | Sony KDL-32S3000 32 in. LCD Television
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Sony grand Wega 50E20000 power light flashes 3 times
Check the fan is coming up to speed when you first switch on it should be high speed then slow down slightly. If the fan is not cooling the lamp the tv will turn off to protect the lamp
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Protect keeps flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Apr 23, 2009 | Sony STR-DE475 Receiver
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
JVC HX-D7 Shelf System Logo
1,149 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
