Question about iLO 2600 Television
26 ilo tv comes on but stuck in composite no functions on side works except for power switch
I have a 26ilo monitor works fine but just in composite mode volume and channels dont function remote works with only power on and off all other functions dont work what seem to be the problem
  • Anonymous May 06, 2009
    I can't access the S-Video inputs either. Same model. Fail.
    Genius:
  • 1,554 Answers
I would contact them on this
http://www.funai-corp.com/support/contact.aspx
in the manual see page 34 for testing the remote
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Posted on Jan 31, 2008
I have an ilo tv and it is stuck on a blue screen when it is turn on and says composite in the top corner. i've purchased a new universal remote that has some ilo codes but none worked. when i do a...
Hello
It is very difficut to get a substitute remote control for your ILO TV. Anyway try these codes with your present remote control. These codes are with AT&T U-verse remote for ILO TV. The codes are:
1412, 1435, 1436
If these codes does not work with your ILO TV, buy one AT&T U-VERSE remote control. It will match for it. OK.
Jun 17, 2011 | iLO 3200 32 in. LCD Television
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
ILO-26HD
You can try this. On remote, hold down menu button until service
menu comes up and then try the factory reset function. If it doesn't
correct the problem, change the EEPROM. It could be corrupted.
I have the same problem but I don't have the original remote to
see if this will correct it with the LCD I have. Good luck. Willy
Feb 22, 2009 | iLO 2600 Television
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Screen is blue says composite, no signal.
TRY AND FIND VIDEO BUTTON ON TV REMOTE AND PRESS VIDEO BUTTON. ON THE MENU USE UP OR DOWN ARROW ON REMOTE TO CHANGE FROM COMPOSITE TO ANALOG TV.
Feb 01, 2009 | iLO 3200 32 in. LCD Television
ILO-26HD
Some times the mico locks up and if you unplug the tv and wait a few minutes then plug it back in, it will go to the default ant 1 input
Feb 14, 2008 | iLO 2600 Television
I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
Dec 29, 2007 | iLO 2600 Television
Will not switch between S & composite inputs
it is out side problem any cable loose or some button must have pressed by mistake is any components.
Sep 19, 2007 | Sony PVM-14L1 14" TV
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Televison & Video Logo
192 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
