I have a whirlpool washer model # lxr6232eq0 it works good until i get to the spin then it stops you can here it try here and there but it never works i tryed to day with out anything in there and it worked so i put a few things in and i got the same thing i'm not sure where to start to take it apart
  • misty_jai Jan 27, 2008
    thank you i will try that
  • 770 Answers
Most like likely you lid switch is going out next time it sticks press down on the lids right side see if it goes if so you will need a new li switch you will see it on the right and the plunger attch to the lid
Posted on Jan 26, 2008
  • Gary Davd
    Gary Davd Jan 27, 2008
    did it work?
6ya staff
SOURCE:
I have a Whirlpool Washer (Model: LXR6232EQ0). It will start washing & then stop. After pulling the timer out & pushing back in, the washer resumes operation. This happen 3-4 times per cycle. ...
You are correct in assuming that the timer is going out. It is fairly easy to replace, you simply take the upper back part off of the washer and remove the screws that hold the timer in place and reinstall the new one.
Mar 02, 2011 | Whirlpool Washing Machines
Missing balance ring clips on whirlpool washer model # LXR9445JQ0
just buy the clips, watch a video to remove the housing of the washer. it is a simple fix. should be below $20 to get the clips, j
http://www.partselect.com/PS874751-Whirlpool-3956205-Balance-Ring-Top-of-Inner-Tub-White.htm?SourceCode=1&SearchTerm=LXR7244JQ1&ModelNum=LXR7244JQ1#Instructions
Jul 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Washer filled, stopped. no cycle will work. switch
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 25, 2010 | Kenmore Washing Machines
My heavy duty washer filled up then stopped working
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.13212200&pathTaken=partSearch
It's likely the the switch was going bad and finally stopped working. following is the easiest test.
May 12, 2010 | Washing Machines
Kenmore washer - water won't drain. It stops
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
WHIRLPOOL LXR6232EQ0 WILL NOT SPIN OR AGITATE
the coupling is broken that connects the motor to the transmission...a $20 part.
Mar 24, 2009 | Whirlpool LXR6432JQ Top Load Washer
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight...
I have a Whirlpool Washer Model LXR6232EQ0. Yesterday something happened after it drained during the rinse cycle. It wouldn't spin. It makes a noise like the moter is trying to spin but there is a slight tinkle once in a while. Could it be the motor coupling or do you think it is the clutch. The agitator doesn't spin at all. does it have a belt?
Mar 17, 2009 | Whirlpool Washing Machines
Whirlpool LXR6232EQ0 Drain Question
See the reply about the lid switch, it's usually the first thing to go on a washer.
Jul 07, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
