Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Spin cycle not working well
The washer has worked for years and we have done nothing to alter the loading, etc. Now, I have usually had to double spin my loads anyway to get enough water out for my satisfaction, however, the clothes are very damp (wet?) now after only one spin. Even after multiple spins they are more wet than they used to be after the regular wash cycle finish spin. I would rather fix this myself if poss, but have no manual.
  • Mindy820 Mar 08, 2008
    Spin cycle not wringing clothes out well. Used to work fine. Lately hasnt been. What do I do?
  • Anonymous Jun 02, 2008
    my spin cycle is not spinning
Jackcfull@yahoo.com
Posted on Jan 26, 2008
  • 770 Answers
Post your email i will send you the book but sounds like you have a partial block in the pump like a coin stuck
Rough, uneven Cotton Load spin cycle
Make sure the washer sits level on the floor and that the machine can't be rocked around due to uneven foot adjustment. The feet usually have rubber cups that cover the metal bottoms--one of the cups may be damaged or missing entirely. Hope this helps!
Jul 01, 2010 | Kenmore 24032\24036 Top Load Washer
My machine will not run the spin cycles, and makes a very loud noise during the spin cycles, sounds like a bad motor or bearing?
I'm not a repair professional. I am just a 78 year man who has done his own washer repair for about 50 years. You might have a bad lid switch that keeps the washer from spinning. You might have an unbalanced load in the machine which makes the noise. The unbalanced load might also be the cause of not spinning.
Nov 23, 2009 | Hotpoint VBXR1090B Top Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
130 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
