Question about MSI K8MM3-V Motherboard
How do you tell what is compatible?
A friend gave me a K8MM3 Micro ATX mainboard, and inside the box was a AMD Sempron 3400+ Socket 754 CPU. Are these compatible with eachother?
  • themoose Jan 27, 2008
    Thank you for your help, I had read the manual for it, and it the whole thing about the 3400+ was confusing the heck out of me. Thanks for clearing that up.
  • lodewijk Jul 17, 2008
    i have no sound the cd that came with the mainboard dos not work.
    What can i do.
  • 23 Answers
I did a Google search for MSI K8MM3-V Motherboard and according to the specs I came across, the CPU and board you have should be compatible .
Posted on Jan 27, 2008
Computer wont start after pressing the power switch.. the processor fan stops together with the power supply...what will i do...i already check the power supply, memory and the different cables inside the...
check *********** board if there are some capacitors that are deformed, busted parts may do the problem , try first to pull out socket,connections then place it back again 2-3 time to avoid corrosion.
Jul 07, 2011 | DFI NF3 250-AL NVIDIA Socket 754 ATX...
Hola tengo un drama la placa madre estaba con un disco duro zata y lo quiero cambiar por un ide pero no me deja botear como lo programo hay alguna manera de poder hacerlo placa madre:amd sempron msi k8mm3...
Placa base MSI K8MM3-V (MS-7181) de VIA K8M800 int. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Ampliar Ver producto en alta resolución K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX sc754 granel.
Producto terminado. Por favor, seleccione los artículos similares en la misma categoría
Ver más productos de MSI.
Código: AA827c
Marca: MSI
N º de producto: 601-7181-020
Enlaces: El sitio del fabricante
Enviar a un amigo
Imprimir
Perro guardián
Añadir a Favoritos
Servicio de Ayuda
Refiera a un amigo
Placa base, placa base, placa madre, placa base, placa madre MSI
Le recomendamos que adquiera junto con las mercancías
Cable de datos al disco duro Ultra cable de datos al disco duro Ultra ATA/66/100/133 ATA/66/100/133 ... 32, -
HUB de alimentación de 1 x 5,25 de energía HUB de 1x 5,25 "... 42, -
Poder adaptadores de alimentación para SATA para la Reducción de disco SATA ... 34, -
Contribuir a la discusión sólo se permite a los clientes
que ya han comprado a nosotros.
Las respuestas a las preguntas más frecuentes aquí.
Descripción de la mercancía K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Calidad Placa base Micro ATX formato a un precio razonable basada en el chipset K8M800 de VIA, que pueda ser equipado con lo último Athlon de 64 bits y los procesadores Sempron con socket 754a Placa base tiene dos ranuras de memoria capaz de transportar hasta 2 GB de RAM DDR tipo 400 / 333 / 266 184-pines. Por supuesto que hay dos canales con interfaz Ultra ATA 133 y dos puertos Serial ATA, un total de hasta seis dispositivos simultáneamente. S3 Graphics UniChrome integrada de gráficos con 8 a 64 MB de memoria compartida proporciona suficiente energía para aplicaciones de oficina y el hogar. Otra extensión permite una ranura AGP 8x para una tarjeta gráfica y tres PCI versión 2.3. Disco también contiene una integrada 10 / 100 Mbps tarjeta de red Ethernet, una de seis canales AC'97 tarjeta de audio, un paralelo y un puerto serie, ocho puertos USB.
Parámetros y especificaciones:
Procesador:
Socket 754 Athlon 64 / Sempron
Chipset:
De VIA K8M800
VT8237R
Memoria:
2 tomas de corriente de hasta 2 GB DDR
Apoyo a 266/333/400 MHz
Las ranuras de expansión:
1 x AGP 8x
3 x PCI
Controlador de disco:
2 x Ultra ATA 133 (máximo 4 dispositivos)
2 x Serial ATA 150 (hasta 2 dispositivos)
Tarjeta de vídeo:
S3 Graphics UniChrome 8 a 64 MB de memoria compartida
Tarjeta de sonido:
Seis canales de VIA VT1617A, 5,1
Cumple con las especificaciones AC97 v2.3
Tarjeta de red:
VíA VT6103L 10/100 PHY
Entradas y salidas:
1 x puerto paralelo
1 x Puerto serie
1 x VGA
PS 2 x / 2
1 x audio I / O (Line-in/Line-out/MIC)
4 x USB 2.0
1 x RJ-45
conectores de expansión:
4 x USB 2.0
1 x Puerto serie
1 x S / PDIF-outNapájení:
1 x 20-pines ATX
1 x 4-pin ATX 12V
Dimensiones:
244 x 215 mm Micro ATX
Mar 05, 2010 | MSI K8MM3-V Motherboard
I need to run Autocad 2010 on my computer but it won't even instal because I have an AMD 3000+ 2Ghz processor. Is it possible to upgrade the processor without buying a whole new computer?
Autocad 2010 needs SSE2 to run.
The only Semprons which didn't have SSE2 are those for socket A, so I assume you're running a socket A mainboard. I checked and there are no socket A processors that support SSE2 unfortunately.
I think that you could replace your mainboard and the cpu cheaply witha a socket 754 mainboard (which supports SSE2 CPUs and should run with your old ram).
However I advise to upgrade to newer system with AM2 socket or so - they aren't expensive and the increase in performance in power-hungry applications such as AutoCad will be noticeable.
Oct 12, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
Sound problem in pc of amd sempron 3200tm
dear if you install the new operting system then install vga and sound card driver then it is solved...if still unsolved then contact me
Aug 21, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Amd sempron
Make sure you go into the bios settings of your motherboard and shut off the on board VGA. You will need to plug the monitor into the onboard VGA adaptor before proceeding to use the secondary adaptor.
Feb 18, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Turboc3 doesnot work in my amd motherboard with amd processor
PC or laptop? socket 754 motherboard for Sempron, with the square hole in the middle with no pins in square hole?
Jan 18, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
IS MCP61S THE SAME AS NF61S MICRO 754
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
About Lan driver
Go to http://www.driveragent.com/?gclid=CImppZvQuZQCFQNHFQodGDBPTg&PHPSESSID=b1p76up33mnnhcn4191kv2g5g7
And register as "New Member" and download your Lan Driver.
Please give me a rating, especially to let me know that I have resolved your problem.
Jul 11, 2008 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
MSI K8MM3-V Motherboard Logo
88 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
