Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Yellow Lamp Light
I have replaced the lamp and cleaned the filter and I still have a yellow lamp light.
  • nonyupie Jan 30, 2008
    I have not checked these fuses - but then I did not know they existed. How do I check the Fuses, what should I look for when I am checking them and what do I do if they are bad. I really do appericate the help.
    Thanks,
    Dale
  • Mitsubishi Master
  • 8,617 Answers
Have you Checked your Ballast or thermal fuse?
Posted on Jan 26, 2008
  • Sonny Berry
    Sonny Berry Jan 31, 2008
    some have a fuse others have a thermal sensor on or near the lamp housing. They also have ceramic IC links(fuses) they are small black rectangles solderd directly to the traces on the back side of the circuit bord check iC links for continuity. Check therma sensor for resistance.
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
Lamp light is still on after replacing bulb lamp
Try removing the filter cover on left side of chassis and cleaning the filter. I had the dreaded yellow/green blinking light , so I removed and put back the lamp (it was ok) and cleaned the filter screen and the light was out, tv came on...all ok!
Sep 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi lamp
Sometimes the same symptom can be caused by the lamp driver (ballast) failing. Also make sure the lamp door and filter door are fully closed. Unplug for 1 min to reboot. When it turns on, you will hear the fans (airflow sound) and then colorwheel spin up (high pitched) and finally the lamp will fire. If the lamp is bad, you will hear the spark gap make a buzz sound for 1 second.. it will retry a few times before shutting down
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
