Question about Maxent MX-26X3 Television
Maxent MX-26X3 My maxent TV has sound picture for about 30 seconds then goes to lines. Can I please get a reply
  • Anonymous Mar 13, 2014
    Maxent LCD makes a popping sound and the TV shuts off. Wait approxmately 1 hour and am able to turn the tv back on but the tv will only work for 2-3 hrs and then the same thing happens again. Is there a board that can be identified as the problem and can it be replaced? Marina Powell
    Scholar:
  • 128 Answers
Call their ucstomer support at 1-888-373-4368. They will be able to help you for sure.
Posted on Jan 27, 2008
  • Omair Chughtai
    Omair Chughtai Jan 27, 2008
    Sorry, I spelled customer wrong above ;)
  • icono Dec 29, 2010
    After taking off the base with 4 screws and another 40ish screws, I noticed that my green heatsink was on securely but it was inadequate to do the job (that circuit gets hot). So I used some tin snips (needle nose pliers would also work) to put a hole in the aluminum shield that covers the whole array of electronics, above the chip. I then mounted a 80mm pc fan to the shield using my drill and 4 fat fan screws that came with the fan. I then made a simliar hole in the plastic case so the air will get sucked off the chip and go right out the back. In hind sight, I could probably have melted some slots in the back using my 110watt soldering iron and it's flat (cutting) bit. It would have looked a littler nicer but who cares, it works! Be careful when testing cause I manged to blow a fuse by shorting the tv with the aluminum shield. don't move it around if the tv has power. Heck I probably shouldn't be messing it with the cover off period but I that's what I get.
  • 71 Answers
More than probably is the LCD control board, but this one is coming with the LCD panel. Could be the main PCB too and I suggest you to call a tech for a exact diagnosys because the parts implied are very expansive.
Posted on Jan 26, 2008
Maxent mx-26x3 video issue
The tv probably does'nt have a fast enough refresh rate to work with games properly. It should be in the manual for the tv, the lower the number the better. I think it's 12 milliseconds on that tv. Have a look here:Response Rates.
Apr 15, 2012 | Maxent MX-26X3 Television
How can i fix static on my maxent lcd tv
26 inch maxent mx-26x3 and 32 inch, l2614xw02 some same parts
When i hear the word static, i think snow,
If while your watching tv and it looks like color snow pixels popping in and out all over the picture i did this to fix it.
look at main board you see a green heat sink,
left of that heat sink you see a 220 uf 16 volt capacitor that half surround by 22 uf capacitors,
change the 220 uf capacitor and snow is gone.
to get it off i just wiggle slowly back in forth until the old capacitor falls off,
then put some fresh solder on and new capacitor on and done.
use a radial electrolytic capacitor not the little metal one they had on
tc
bagabillion
Jul 11, 2011 | Maxent MX-26X3 Television
Maxnet mx-26x3 tv toconnect toan HDMI input
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Jun 10, 2011 | Maxent MX-26X3 Television
My screen will be okay for about 30 seconds and then go to nothing but tons of little lines across the screen. The sound is fine but no picture - just lines. What can I do?
Problems on your video board and also maybe power supply problems, the caps in most of these sets are the blame. So look for bad caps, you tube has video on how to fix some sets
Jan 03, 2011 | Maxent MX-26X3 Television
On my Maxent television there is not co-axial hook-up for cable connection. The cable company does not have a tuner box, what should I do to get it working?
If you have a vcr ,you can come out of the line out of the vcr.the cable box would hook to the vcr,out of the vcr to the tv. this might help
Jul 14, 2009 | Maxent MX-26X3 Television
Maxent MX-26X3
what kind of connection are you useing cable, dish, attena... and how do you have it connected ... direct connect from a cable box or threw a vcr also are you running coax cable or the colored audio video cables?
Oct 16, 2008 | Maxent MX-27X1 27 in. HD-Ready LCD...
Time warner cable box doesnt have a code for maxent mx-26x3
Code for gateway works. I used 206 on my universal remote. I have a Phillips remote.
Aug 08, 2008 | Maxent MX-26X3 Television
Maxent MX-26X3 MODEL L2614XW02
Tcon board issues or the cabling going in or out of it
Nov 30, 2017 | Maxent MX-27X1 27 in. HD-Ready LCD...
No picture only everythings working fine
someone gave me a maxent mx26x3 with the same problem. I took the back cover off, and then the metal shield covering the PC board. There is a green heat sink on the main processing chip. The heat sink was not making good contact. I slightly twisted and pushed the heatsink on the the chip, and the picture stayed perfect now for 2 days. I think the heatsink will eventually need to be re-glued on with thermal expoy glue. It will be a pain to remove and clean though.
Sep 11, 2007 | Maxent MX-26X3 Television
Televison & Video Logo
477 people viewed this question
Top Maxent Televison & Video Experts
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
